Aluminum heads vs spark plugs
That's actually a very polarizing question. AFAIK new style plugs with nickel coated threads don't need anti sieze. The manufacture may specify on their website.
The poeple that say never use anti seize on spark plugs usually say it can cause over torquing of the plugs, or that it makes the plugs contain too much heat, or that it affects the electrical connection between the plug body and the threads.
With that said, I always apply a VERY sparing amount with a q-tip, then use a torque wrench. I feel most of the problems associated with seized spark plugs are to to people over tightening.
From an engineering perspective, that anti-seize will change the friction, and could lead to over-tightening. I'm not an automotive engineer, so I can't say how much this matters, but given the troubles some people have had with spark plugs on various engines, I would be pretty careful.
In industrial applications, i've seem anti-seize compounds reduce friction by up to 40%, which is pretty huge.
I use anti-sieze and then tighten the plugs down by hand, I have never used a torque wrench. Some cars I have you are lucky to get any tool on the plug let alone a torque wrench. I have been wrenching long enough to know what tight is, calibrated wrist
I cringe every time I have to pull a plug from an aluminum head that I did not install.
I could post a long and in depth post about the use of antiseize on plugs .
I tire of banging my head on that wall .
I do Not recommend the use , as do many publications , spark plug manufacturers , and automotive and motorcycle manufacturers .
The problems are too many to list in this limited forum .
Torque alteration , flash over , heat dissipation , conductivity .......
Not recommended .
Not recommended .
If properly installed , properly maintained , Not an issue .
