2004 nagivator rear wiper problems.
Old Feb 21, 2016 | 11:31 AM
vickers57's Avatar
vickers57
I have a rear wiper motor that has gone bad. I was able to get in and disconnect the wiring from the motor. my problem is now I can't get the rear glass open to take panels off so I can replace the motor. I bought a motor just can't get the back glass open to remove 2 screws. any help would be great thank you. Roger
Old Feb 22, 2016 | 03:35 PM
r2millers's Avatar
r2millers
I'd reconnect the wiring, get a helper and while you turn on the wiper switch, have someone else help turn/twist the wiper assembly arm aggressively.
The sleeve bearings dry out and commonly stick.
Once loose, you can decide to change out the motor or not.
Old Feb 23, 2016 | 12:07 AM
alloro's Avatar
alloro
If you mean because the arm is up then remove the arm.
Jesser02EX
Aug 28, 2016 05:10 PM
Scout
Feb 4, 2010 09:08 AM
CobraGT40
Oct 27, 2009 03:59 PM
mrslate
Mar 28, 2005 02:56 PM
chengg02
Aug 11, 2003 10:34 PM
