My 1967 F100 build - Ford Truck Enthusiasts Forums
My 1967 F100 build
Old 02-20-2016, 08:10 PM
itsabullitt
itsabullitt is offline
itsabullitt has a good reputation on FTE.itsabullitt has a good reputation on FTE.itsabullitt has a good reputation on FTE.
My 1967 F100 build
I picked up my '67 F100 in the Summer of 2013. A fellow FTE'er and close friend Flip4Ford had previously donated a 429 big block for help my brother and I gave him getting his '63 back on the road. Another FTE'er and good friend smokenchoken posted up in the Kansas chapter that he knew of an old F100 that was on it's way to the scrapper if somebody didn't come buy it. I got to thinking this would be a good candidate for the 429 and C6 that was just taking up space in storage.
It would've been a shame for this one to go to the scrapper.
I ended up bringing it home for $400.00 with no motor, but otherwise a complete truck. It's straight except for a pretty nasty dent in the driver's door. It doesn't show well in the pic and it doesn't seem to effect how the door closes or window operation. I think it gives the truck character and plan to leave it. I also picked up a straight replacement '67 door if I change my mind. The driver's side floor pan is toast and the interior pretty much needs to be completely redone.
It cleaned up pretty nice for just hitting a coin op car wash.
I lucked out and scored a complete dent side chassis with a 460 on Craigslist for $100.00. I robbed all the power steering and front suspension components off it and sent it to the scrapper and got almost all my money back.
It's basically sat since then. My brother and I have finally started tackling a power disc brake swap. We pulled the old front suspension and brakes out.
Today I spent some time with an angle grinder with a wire wheel cleaning all the dirt and grime off the engine cross member. It was fairly clean considering it's age. there was more dirt and mud dobbers than grease and oil. My brother and I swapped out the original 300-6 frame perches for the big block perches and swapped out the old crusty steering gear box for a power steering box.
This is just temporary as I want to make sure everything fits together before we tear the front clip off. I'll go back and finish cleaning and painting the frame and cross members once it's all exposed.
Now that I've started working on it, I've found some problem areas that need attention. It turns out it's not gonna be as cheap of a build as I originally thought, but oh well it's just money. It needs new inner fenders, cab mounts and a radiator core support. I bought new inner fenders and cab mounts at our local swap meet. I just need to order a core support and will probably end up getting the dent side version for the bigger opening since I'll have the big block. Once it's back on the ground and rolling it'll go to a buddy's body shop to have these parts installed.
I want to thank everyone that has posted their builds and provided answers to my questions. I'm sure I will have several more as the build progresses. I'll update the thread as I go. This is my first Ford truck and I am looking forward to getting it back on the road.
Old 02-20-2016, 08:49 PM
JTool's Avatar
JTool
JTool is offline
JTool is starting off with a positive reputation.
I look forward to seeing the progress. I have '67 F100 as well and hope to get it back on the road soon as cheaply as I can (just needs brakes) and then do all the work to it that I have planned, as I have time and money.
Old 02-20-2016, 09:01 PM
ultraranger's Avatar
ultraranger
ultraranger is offline
ultraranger has much to be proud ofultraranger has much to be proud ofultraranger has much to be proud ofultraranger has much to be proud ofultraranger has much to be proud ofultraranger has much to be proud ofultraranger has much to be proud ofultraranger has much to be proud of
That truck is in way too good of shape to go to a scrapper. You got a smokin' deal for $400 bucks.
Power brakes, front discs and power steering are the best things I've added to my '69 F100 short bed Ranger. Now, if I just had A/C in it..... that will come, eventually.
Old 02-20-2016, 09:48 PM
itsabullitt
I agree. It was waaaay too nice to be scrapped. The previous owner just needed it gone in a hurry due to some personal issues. I originally planned to just drop in the motor and trans and fix the brakes to get it back on the road. Then the bumpside forum got ahold of me. After reading through all these build threads I just couldn't half *** it. I've spent 2.5 years collecting parts and saving money. It's still going to be a long road ahead, but I plan to take my time and do it right.
Old 02-20-2016, 10:07 PM
ultraranger
I did the same thing with my disc brake I-beam front suspention, power steering parts, tilt column, etc. I got the donor parts and then one-by-one started cleaning them up, ordered the parts to rebuild one assembly, stuck it to the side and covered it up and then moved onto rebuilding the next item and so on.
Once everything was cleaned up and rebuilt, it was time to start tearing old parts off the truck and put the newly rebuilt parts on.
Initially, I had about 5 things I was going to change on my truck and I figured it would take maybe 2 or 3 months to swap everything over. After I started taking parts off, I thought, "while I'm doing this, that needs to be changed/fixed/modified." Before it was over, the truck was down for nearly 6 months and instead of just changing 5 things I ended up changing about 14 things in all --some minor changes, some major changes.
It's easy for things to 'get out of hand' once you start fixing things on the old truck.
Old 02-20-2016, 11:43 PM
JEFFFAFA's Avatar
JEFFFAFA
JEFFFAFA is offline
JEFFFAFA has a brilliant futureJEFFFAFA has a brilliant futureJEFFFAFA has a brilliant futureJEFFFAFA has a brilliant futureJEFFFAFA has a brilliant futureJEFFFAFA has a brilliant futureJEFFFAFA has a brilliant futureJEFFFAFA has a brilliant futureJEFFFAFA has a brilliant futureJEFFFAFA has a brilliant futureJEFFFAFA has a brilliant future
Well I'm going to enjoy this Bump "movie". 429 and all. Always thought that was a Cool number. Right behind 427. Gotta go nuke some popcorn.
Old 02-20-2016, 11:45 PM
GaryKip's Avatar
GaryKip
GaryKip is offline
GaryKip is a splendid one to beholdGaryKip is a splendid one to beholdGaryKip is a splendid one to beholdGaryKip is a splendid one to beholdGaryKip is a splendid one to beholdGaryKip is a splendid one to beholdGaryKip is a splendid one to behold
That is a good "save", from the metal scrapper. You're on the right track about how to start your rebuild! I'll watch it grow from here.
Old 02-21-2016, 07:50 AM
68murc's Avatar
68murc
68murc is offline
68murc has a great reputation on FTE.68murc has a great reputation on FTE.68murc has a great reputation on FTE.68murc has a great reputation on FTE.68murc has a great reputation on FTE.
Big blocks are fun in these trucks.
Don't expect the back tires to last very long.....
Old 02-21-2016, 10:48 AM
ultraranger
The rear end needs a Traction-Lok differential so both rear tires will wear evenly.
Old 02-21-2016, 02:07 PM
itsabullitt
Yep. It'll be getting a trac lok for sure. I need to do some gear ratio calculations before I settle on a ring and pinion. Thinking somewhere between a 3.0 and 3.50 with 31" tires.
We got the front beams and new bushings installed today. Will torque everything down and install the new rotors and calipers this week. Hope to have it back on the ground and rolling soon.
Old 02-21-2016, 02:14 PM
itsabullitt
I'm looking forward to it. Not only is this my first Ford truck, it's my first big block too.
Old 02-21-2016, 03:41 PM
ultraranger
3.00:1 rear end gears will be nice cruising out on the highway but for all other times --particularly if you're going to pull a loaded trailer, they are going to be a dog.
3.50 or 3.70 rear end gears will put the engine higher in the RPMs out on the highway but the truck will have better acceleration and much better ability to pull a heavy load without bogging down the engine.
If you had an overdrive transmission, you could have the better gearing of 3.50 or 3.70 for accelaration/pulling but, you would also have the advantage of lower highway RPMs when in overdrive.
Old 02-24-2016, 09:33 PM
itsabullitt
Front end is back under it. Has new rotors, calipers, shocks and big block springs. Hit the beams and section of frame with a wire wheel to clean them up and added a coat of paint. When the fenders come off, I plan to wire wheel the whole front frame section and coat it with POR15. A whole lot of black under the front.
Also installed is the steering column, power booster and master cylinder.
Next is to run the brake lines and bring her home. So far we've been working on it in a storage shed we've been renting for the past few years. We finally had a garage built that takes up most all of the back yard. It'll be finished by the end of the week so we'll finally be able to work on it at home instead of driving across town.
Just for fun, my big block corner. The 429 is on the stand and my pile of 460 craigslist score.
And a question for the Ford pickup gurus here. Back in the day, was it common to mark the underside of the hoods on these old trucks? At first I thought maybe it was a replacement hood from a salvage yard, but the date being 3/24/67 is what seems odd if that's the case.
Old 02-24-2016, 09:47 PM
instig8r63
instig8r63 is offline
instig8r63 is gaining momentum as a positive member of FTE.instig8r63 is gaining momentum as a positive member of FTE.
...And a question for the Ford pickup gurus here. Back in the day, was it common to mark the underside of the hoods on these old trucks? At first I thought maybe it was a replacement hood from a salvage yard, but the date being 3/24/67 is what seems odd if that's the case.
Factory grease pencil marks...during assembly, inspection, etc.
Old 02-25-2016, 05:25 PM
Tylus's Avatar
Tylus
Tylus is online now
MMNC (SS)
Tylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputation
subscribing for the awesome sauce
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
