1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
2008 6.8L F250 Crew Cab Keyless entry
Old 02-20-2016, 01:11 PM
onelowhog's Avatar
onelowhog
onelowhog is offline
I have been through multiple forums trying to solve this problem. Hopefully someone here can help. I am trying to set a personal code for my keyless entry. I have the factory code and everything on the key pad works:
Factory code unlock drivers door and moves power accessories
7-8 9-0 lock doors
3-4 unlocks all doors after factory code is put in.
However when I put in the factory code and press 1-2 to set a personal code nothing happens. The locks do not cycle even after putting in a new five digit code. I have also tried going through the key fob process (cycle key eight times....) Everything works except for when I try to program keyless entry it does not cycle the locks. I know the 1-2 button works because it is part of the factory code which again preforms as it should. Any ideas? Thank you
MattsExcursion
10-16-2006 07:51 PM
automaticj5
1997 - 2003 F150
07-28-2005 04:06 PM
wipper
02-28-2005 06:24 AM
ec rider
05-17-2004 07:09 PM
Quick Reply: 2008 6.8L F250 Crew Cab Keyless entry
