problems with front rotors and brakes
Welcome to FTE spt!!
If it only has 23K on it, I would make the dealership deal with it. Are you having problems stopping, are the brakes grabbing or feel tight? Your ABS might be building too much pressure on the front and not releasing correctly, causing the brakes to drag and heat the rotors excessively.
I would have the dealership test them and fix them...
