Replacing the fuel/feed pump on my 97...
In the process of replacing the water pump and doing a system flush, I noticed the galley area has a nice puddle of fuel laying in it. With the truck running I noticed the seam on the fuel pump (diaphragm area) has fuel kinda bubbling out of it. So it looks like I'll be replacing it pretty soon. While I'm in there, is there any other areas I should pay close attention to regarding the fuel system? It idles a little rough occassionally, could this be the reason for it? Is there a preferred brand of pump I should buy?
Okay, I wasn't sure. I have had good luck with Delphi parts on my IDI, I guess I'll go that route. Yup, I was planning on replacing any and all rubber fuel lines. Also I was reading something about getting a seal kit for the fuel bowl, regulator, and bango fittings. Good idea?
Yeah I'm thinking so, definitely don't like having to do things twice. Looks like it all has to be removed to get the fuel pump out anyway. Any recommendations for sourcing these parts? Thanks again for the replies.
It's a bad website for most of us! Quite a few guys run a ts chip, but if you plan on many mods in the future you'd be better off with a hydra chip. No more sending the chip in for reburns, the tunes are emailed to you and you download them onto the chip. You should replace the stock downpipe at the minimum for exhaust, new intake, and gauges if you do a chip too.
See, I'm already spending more of your money! Don't tell your wife...
Really? I suppose they don't help much for cooling, I do like the idea of the added capacity. I am running a deep pan in my 84 IDI, that truck used to have AC but I deleted it and converted the condenser to an auxilary trans cooler. I don't have a temperature gauge on it yet, but I have only overheated it one time. I got stuck one night when I was snow plowing, got a little pissed off and started really hammering on it (like an idiot) until I got it out. Of course it's a C6, you have to be pretty hard on one for a long period of time to kill it. The funny thing is, I had no idea there was anything wrong, it drove perfectly fine until I got home later that night. I noticed it was puking fluid out of the pump seal in a steady stream. I let it cool down and topped off the fluid, never had an issue since. I guess the biggest thing that sells me on a deep pan is the added capacity, plus they usually have a drain plug and a drilled and tapped location for a temperature sensor. I add a drain plug to every transmission pan I drop, makes future servicing a whole lot cleaner and easier.
I tried one of the "Help" brand drain plug kits with the rubber washers and the hollowed out bolt with the drain plug in the middle. Seemed a little sketchy to me. I'm not sure if I've seen one of the B&M kits before. I drill a 1/2" hole in the bottom, or the side (as close to the bottom as possible) of the pan and weld a grade 8 nut 1/2-20 on the inside of the pan. Just a couple short beads across from each other on the flats of the nut is all it takes. Then I use one of replacement 1/2-20 flanged drain plugs with the nylon washer, works perfect and looks like it came that way from the factory.
This makes the filter change the messiest task.
On my truck, I use a center punch and let the filter drain. The rag I use to spin off the filter captures any drips.
On my wife's Explorer, the filter is horizontal but I also center punch it to drain it. The rag I use to spin it off contains the remaining oil that may drip.
