Best and worst purchase of my life - 1978 f150
I decided to buy this 1978 f150 off Craigslist.
Originally listed for $2400 it was out of my budget... But luckily next time I checked Craigslist later that week the price had been dropped to $1000. I called him up and went to test drive it. Drove alright and decided to go with it. He had a few offers on the truck from guys wanting to part it out, but went with me because I was the only one who wanted to actually do something with it. It came with a new Holley 600 Carb, new aluminum heads, 3" body lift and 8" suspension lift.
I bought it knowing it had several problems and went about starting to fix them.
The rear intake manifold gasket was blown, the shift linkage needed adjustment because it would slip out of park into reverse, and the transmission vacuum shift valve needed fixing.
I went ahead and replaced the intake manifold gasket... And pulled the dizzy. Couldn't get the timing set again. Since I didn't have any experience with timing and couldn't get it done, I sent it to a shop. Turns out the starter was also going out and the tires were from 1995 and dry rotting.
Had a GMC distributer put on it, new wheels, 37" tires and just now found out the Carb has an issue too, probably vacuum related.
Next free time will be spent checking the vacuum hoses and seeing if the Carb needs rebuilding.
Current to-do list:
Inspect Carb for vacuum. (Vacuum could also be messing with trans shift modulator?)
Trans shift switch
Brakes full inspection
Fix loose steering
Camo paint job
To-done list:
New wheels and tires
New distributer, plugs, wires
New starter and starter solenoid
Oil change
New air filter
Current to-do list:
Trans shift switch
Fix loose steering
Camo paint job
To-done list:
Oil change
New air filter
If you've just had the intake mani off squirt a little carb cleaner or starting fluid around the base also around the base of the carb while the engine is running. If the rpm's go up you've found your leak. Look real close at all hoses also the one going to the vac. modulator on the tranny. Hang in there... this is suppose to be fun. Good luck!!!
1. Have you joined the Tennessee FTE chapter? Tennessee Chapter - Ford Truck Enthusiasts Forums
2. Join up and make friends with any and all folks in your area. If not in your area ask around for a hand doing things like setting the timing ect.. You will learn nothing by just paying the work bill. You need to get your head under the hood and your hands dirty.
3. I know you know this, I am motivating you. Hang in there, we were all not born with a wrench in our hands. And having a helping hand or a at least a guy that knows a little bit about it can lead you down the right road.
All you had to do was a little bit more reading and get the distributor cap rotor tip pointing to the #1 cylinder, BEFORE you pulled the dizzy I bet.
You did the manifold, you can do the rest. Get a cheap paper back Chilton or Hanes manual to start, and also get a actual Ford shop manual on CD to really get into it.
Did the shop tell you the tires were shot and the starter was bad? YOU could of done the starter yourself. Should of told the shop that you will take care of the tires in the parking lot.
Advanced search, read threads, ask questions, read more threads, tons of experienced folks on here.
Adjusting the linkage and replacing the trans vacuum modulator it easy.
Be systematic and knock out the basics - get it to start, stop, and run reliably and safely.. no hacking allowed! Do it once and do it right.
Establish baselines for fluids, belts, ignition components, and yes, rebuild the carb regardless of what it looks like because then you know it has been rebuilt with attention to detail.
Looks come last unless you have the luxury to work at it wholistically.
Nice paint is overrated IMO.... dents add character. If the paint is shot... go camo like I did.
Front brakes shoes and or new rotors, calipers, flex lines...or rear drums, shoes, rear wheel cylinders. Master cylinder and or power brake booster?
You will need a 4 pt hub socket and a ft lb torque wrench (rentable) no matter what.
Might as well just replace the front wheel bearings and be ready to do a front hub repack during reassembly. Races can be knocked out and back in, but a hyd press is way better IMO.
Figure out what the problem is (weak brakes?) and go from there. Might just need a good bleed job? Or all the parts listed above.
X2 on start, stop, run and steer. And of course shift is in there too.
about how long did it take you? Also any paint recommendations and expected total cost?
