The "name that part" thread
Old 01-27-2016, 08:05 PM
Tomahawk's Avatar
Tomahawk
Tomahawk is offline
I almost have my truck put back together and I have two shoulder bolts that I believe came off when I was removing the front clip, engine and transmission from the truck...that's about the time I noticed them on my workbench. I'm about to put the front clip back on and I still have no idea where they're supposed to live.
The threads are 3/8-16, the shoulder is 7/16" diameter and 1/4" long and it has a 9/16" hex head. It looks like they were coated with Loctite. Thanks for your help!
Old 01-27-2016, 11:28 PM
willowbilly3's Avatar
willowbilly3
willowbilly3 is offline
They look like hood hinge bolts for a 40-47, never seen anything like that on a bump that I can remember.
Old 01-28-2016, 09:33 AM
Freightrain's Avatar
Freightrain
Freightrain is offline
Don't think they are factory for anything I can think of. Don't think they had red loctite on factory bolts back then.
Old 01-28-2016, 12:44 PM
JEFFFAFA's Avatar
JEFFFAFA
JEFFFAFA is offline
Shoulder belt bolts? For those threaded holes by your shoulder?
Old 01-28-2016, 01:06 PM
Freightrain
Think those are torx heads.
Old 01-28-2016, 02:08 PM
Ford_Six's Avatar
Ford_Six
Ford_Six is offline
Rag joint maybe?
Old 01-28-2016, 02:48 PM
qman's Avatar
qman
qman is offline
Dikkfoure.
Old 01-28-2016, 03:59 PM
351Cleveland C4's Avatar
351Cleveland C4
351Cleveland C4 is offline
I sure don't recognize those from a bump truck. Maybe to put frame members together? Engine perches perhaps?
Old 01-28-2016, 04:04 PM
Tomahawk's Avatar
Tomahawk
Tomahawk is offline
It only had lap belts.
Originally Posted by Ford_Six
Rag joint maybe?
It doesn't have rag joint.
Originally Posted by qman
Dikkfoure.
Nope, but they could be parts from the hennway or there off the old commencer.
That's what I was thinking, they were off the frame or trans. mount?
Old 01-28-2016, 04:19 PM
JEFFFAFA's Avatar
JEFFFAFA
JEFFFAFA is offline
Aftermarket bolts taking the place of the rivets for the radius arm brackets to frame? A lot of guys have cut out those rivets to change the radius arm bushings rather than messing with the suspension.
Old 01-28-2016, 04:25 PM
Tomahawk's Avatar
Tomahawk
Tomahawk is offline
Oops....sorry guys, I did forget to mention the bolts are from the Highboy.
Old 01-28-2016, 09:58 PM
grinnergetter's Avatar
grinnergetter
grinnergetter is offline
I've seen that style on the top lid for a 4 speed but I dont think the shoulder was quite that long.
Old 01-29-2016, 06:56 AM
69pig-penf100's Avatar
69pig-penf100
69pig-penf100 is offline
I have two bolts that look just like that. Only problem is that although I bagged and labeled most parts the one that looks most like it wasn't bagged but I think it went to a bracket I'll have to double check and see if I can find any more other wise the other one in the picture has a smaller head and that one went to the brake pedal connection from the master cylinder
I'll see what else I can find later tonight when I go work on my truck
Old 01-29-2016, 09:50 AM
Freightrain
^^That bolt looks like the brake pedal pushrod bolt.
Old 01-29-2016, 04:41 PM
Tomahawk's Avatar
Tomahawk
Tomahawk is offline
Maybe?
Attachment 135312
Thanks for checking.
Yes it does, with the thin hex head.
Could they be from the brake warning switch/proportioning valve or the pivot mounts on the engine and frame for the clutch z-bar?
Quick Reply: The "name that part" thread
