I'm searching for an after market steering shaft assembly for my '91BroncoXLT.
Any links would be greatly appreciated.Tried a couple of sites but no luck with my model year.
Thanks
Hey there Sudsrat! Borgeson.com can set you up. They are a bit pricey, but come with one heck of a warranty.
Hope they can help you.... Talk with you later...
Yeah, they don't list everything they have or manufacture. Or else, I wouldn't be able to navigate through it! HEE HEE! I'm sure they'll have what you need, or they'll have it made for you in a couple of days. I'll talk with you later....
Thanks scooter.My steering and handling is still a little sloppy,
even after new upper & lower ball joints,axle u joint and I had my steering box replaced about 35k ago,but was told by a reputable
place that it is still good.Radius arm bushings also good.So I'm going to see about a new steering shaft and see if it helps.
