1978 f250 ford Cummins restoration! - Ford Truck Enthusiasts Forums
Old 02-07-2016, 02:35 PM
scottmorgan1309
scottmorgan1309 is offline
scottmorgan1309 is starting off with a positive reputation.
OK so I started this restoration and Cummins swap 1/4/16
Things are going along pretty good! I'll update where I am today!
Plans are to take an old farm truck and make it shinny!! Everything will be clean beautiful and most of all reliable!
Old 02-07-2016, 03:33 PM
77&79F250's Avatar
77&79F250
77&79F250 is offline
Used OEM parts guy
77&79F250 has a spectacular reputation.77&79F250 has a spectacular reputation.77&79F250 has a spectacular reputation.77&79F250 has a spectacular reputation.77&79F250 has a spectacular reputation.77&79F250 has a spectacular reputation.77&79F250 has a spectacular reputation.77&79F250 has a spectacular reputation.77&79F250 has a spectacular reputation.77&79F250 has a spectacular reputation.77&79F250 has a spectacular reputation.
Welcome to FTE, nothing is really "for real", unless we see pics! So..............this thread is worthless without pics.
Old 02-07-2016, 06:50 PM
650's Avatar
650
650 is offline
650 is starting off with a positive reputation.
Subscribed. I love watching Diesel builds
Old 02-07-2016, 09:19 PM
katzklaw's Avatar
katzklaw
katzklaw is offline
katzklaw is gaining momentum as a positive member of FTE.katzklaw is gaining momentum as a positive member of FTE.
subscribing also. i'm interested in dropping a diesel in my truck, so always looking for more info and ideas
Old 02-08-2016, 06:30 AM
scottmorgan1309
last winter
ok so last winter I un f'ed up my truck...
the previous owner had put in a 390 FE motor..
im sure there is plenty good with the 390 if done right but this was just not done right...
the truck sputtered and had no power... I could barley pull 4th gear...
so I dropped in a 460 and a c6 auto!!
here is some pictures of the truck when I bought it!!
Old 02-08-2016, 06:32 AM
scottmorgan1309
just a couple more shots!
Old 02-08-2016, 06:33 AM
scottmorgan1309
now for the fun stuff! the original motor swap!!! from a junk 390 granny low 4speed to a mild 460 c6 build!
Old 02-08-2016, 06:39 AM
scottmorgan1309
460 is in I thought it was there to stay...
Old 02-08-2016, 06:43 AM
scottmorgan1309
time to resore this truck!
so I got a wild hair one day and started to jump into the restore project!
Old 02-08-2016, 06:48 AM
scottmorgan1309
all in a weekends work!!
Old 02-08-2016, 06:54 AM
scottmorgan1309
ok so I skipped a ton of work!!
I took out all the rivets and all the brackets and cross members!!
I set up a harbor freight shed in my shop over my frame... I sand blasted the hole thing! then I coated it with por15
I also blasted all my brackets and small stuff that would fit in my cabinet..
the leaf springs and other larger items where done out side..
Old 02-08-2016, 07:01 AM
scottmorgan1309
ok so someone may have to resize all these images.... im not sure how to do that but I willing to try if anyone has an idea how..
Old 02-08-2016, 07:03 AM
77&79F250's Avatar
77&79F250
Used OEM parts guy
Impressive, very impressive. Thanks for the pics, can't wait to see it done.
Old 02-08-2016, 07:05 AM
77&79F250's Avatar
77&79F250
Used OEM parts guy
Don't you hate it when a mega-sized image gets posted and you end up having to scroll side to side to see the complete posts on that page? Automatic image resizing software has been added to the site! You can access this feature through your UserCP > Edit Options> Thread Display Options> The Image Resizer. If you leave the fields blank, all images larger than 400px in width or 600px in height will be resized down to approximately 400px in width or 600px in height. If you enter a 0 into both fields, then the feature is disabled and you won't see any resizing. You can also set a custom size if you want to. Just be sure to scroll down and click "Save Changes" if you do anything other than leave the fields blank.
Old 02-08-2016, 07:18 AM
scottmorgan1309
alright! now that all my pictures fit on the screen I got more!!
Thanks 77&79F250!!
Quick Reply: 1978 f250 ford Cummins restoration!
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
