1978 f250 ford Cummins restoration!
ok so I picked this Cummins up for 900!!
the f150 did not like it one bit..
I had to build a homemade cart stand for the motor...
I put it on the heavy duty engine stand I had and because its three legs it tipped over....
I guess you live and learn..
I cracked the time housing and I also broke the vacuum pump..
Its all good and so is the hard work on your Ford truck!
$.02, flip the rear shock (top) mount bracket (lone one behind your body mount bracket) over and cut/grind the way to small drain groove a little bigger. To help with it draining and not clogging up with road dirt.
ill look into that tonight! if it helps with corrosion I'm all ears here is a picture of the other one that is going to be replaced.. I painted with the orange im using for all the bolt on parts...
im going with and orange and black theme..
Here is a great diesel swap thread and great motivation to stay with it. https://www.ford-trucks.com/forums/1...ht=diesel+swap
I read that whole Thread last weak!! I was looking for engine mounting ideas and cross member modification ideas and I got hooked...
needless to say I was very unproductive at work last weak...
It rides nice because of this..
I use it for my every day use and I can say I enjoyed my 2004 silverado much more.
My sister has the same truck and here engine is under powered to..
Oh and anything under 2004 has regular spark plugs.. alot of people think all 5.4 have the spark plug problem but that didn't come about until the 3v newer 5.4
Oh and I also had to change the tranny at 160,000 miles... the tranny leaked out the front seal and the previous owner must have figured out that if you run it out of fluid it stops leaking.. my sisters has 180,000 factory tranny and it runs strong!
#29
oh if anyone can help me along...
im looking for a hanger... it the front suspension rear mounting hanger.. it looks like this!
when I put the 460 in I removed them and scrapped them and replaced them with my own bracket.. I put dual exhaust in that was really tight to the frame...
