1949 Ford F1 rear end ratios
UPDATE: I got the new ring gear and pinion installed. No problems at all - got everything from Early Ford V8 Sales including a seal and bearing kit.
The pickup drives GREAT. No doubt, the acceleration is NOT what is used to be with the 4.27 gears in it, but the truck can get to 70 mph without any effort or stress on the old flathead. I think the drive-ability around town is fine. I don't carry or tow anything with this truck, so I was not worried about dropping this rear end ratio in the truck.
For anyone with a Dana 41 rear end, this kit is a viable alternative to swapping out the 41 for a 44 or a 9".
Count me as "satisfied".
Not on my 49 F-1, but if the stars align, the rivers run backwards, and donkeys fly, I will most likely go that route with my 50 F-1 restomod when i work on it again one of these years. 9 inch rears are a very rare thing in this part of the country nowadays.
After making this swap and driving for a few days, here are my observations on changing from 4.27 to 3.54 rear end ratio:
1. The driveability is great - moving from a standing start in 1st gear is not really noticeably different.
2. The main difference is 2nd gear - the shift from 1st to 2nd does not come as quickly and you definitely stay in 2nd gear longer before you get the rpm's up to shift into 3rd.
3. It really cruises effortlessly at 70 mph with no problems. I think 75 may be a little much, but it is even doable in my opinion.
All in all, this was an easy swap as compared to swapping in a Dana 44 or a 9" rear end and I really don't have any regrets at all. With the new ring gear and pinion, all new bearings and seals, I spent about $500 in parts.
49willard
03-12-2015 08:16 PM
ct50f1
07-14-2010 07:27 PM
