Because Race Truck
#62
I'm supposed to be in Hawaii right now, but we had to postpone. So I'm fiddling with the truck some more. I got the injectors, valve train, intake plenums, and uppipes done today. Next up will be high pressure oil pumps and figuring out which route I want to go with my turbo oil return this time.
Unlimited Diesel did my injectors this time because Jim does not have the tooling to do bigger than 350cc. These are 450/400s.
#63
#66
No sir, I sure didn't. My 400k mile engine had one cylinder down around 320psi compression, so I decided to try this one. This engine is a 300k mile engine I yanked from a wrecked truck about a year and a half ago. I plan on building my factory engine to handle the power while I run this one detuned. I have the parts to make 1000+hp. I just don't have the parts to hold that power. I'm gonna try running this one around 800hp for awhile with an extra 100hp or so of nitrous on stand by in case I need it mid way through a pass. There's a couple 900+HP 6.4s in my area that say 7.3s are slow and I'd like to prove them wrong with a stock engine.
Edit- I almost forgot. I added one more part to the list that I didn't originally intend on. I'm doing a water to air intercooler on the truck. I came across a deal on a 2000hp Spearco water to air cooler that I couldn't pass up. So I'll be running that with ice water instead of the DI intercooler I was running.
#67
#68
#70
Nope. I'm curious if the irate mount moves the 400 series charger to the pass side. I have 3/16" thick plenums and my inlet side is ON the plenum. Those di plenums are pretty sexy! Wish I had room. I sunk my charger WAY down to clear the could.
Travis knows this mill is just temporary...his old one made 500s for years. Detuned a bit it'll last a while...ask matt Maier...
#72
Aaron, I haven't test fit the turbo yet. This isn't an Irate setup, it's a Carson Stauffer mount. I talked with him about the plenums before he built the mount and he said that he thinks it will clear with the S400. If it doesn't, I'll just spring for another set of Riff Raff plenums. I've been happy with the Riff Raff Plenums on my SD so far.
My girlfriend said that the truck has to be done before April so that I can make the Texas Diesel Nationals race. That's another reason for throwing it together with stock rods. I can't fund a billet rod engine in that short of a period. I'll need a good year or so to fund a billet rod engine with ported heads, cam, and all that nonsense.
#75
