1989 F350 4X4 4-door, 7.5L 460
code8 R-(test failure, hard fault repeat sequence
6 O-(fuel pump secondary circuit high speed fuel pump relay open
:22 R-O-C-(manifold absolute pressure BARO sensor out of range
These are the codes I was able to pull up on the new code reader.
Last edited by ssfisher; 02-10-2016 at 06:35 PM. Reason: Stupid smiley face was found in post. Once posted!
code 98 R-(test failure, hard fault repeat sequence
96 O-(fuel pump secondary circuit high speed fuel pump relay open
Workingstiff
09-14-2018 11:45 AM
doorpro
11-20-2003 07:08 PM
