97 7.3L died on freeway
Old 03-03-2016, 05:52 PM
drun's Avatar
drun
drun is offline
Got my PCM back and installed. Did ohm test from IDM plug out to injectors and back. All wiring/ injector solenoids tested good,(2.8-3.1 ohms). Ran snap on injector buzz test,(only 1 buzzed/ 7 just clicked). All other tests good/ no codes.
I guess I got a bad IDM to replace!
Now, can I use any 2000 IDM in a 97 Cali 7.3? Or do I have to buy a 97 Cali and modify? Cause I wanna 120 volt IDM.
Old 03-03-2016, 07:48 PM
madpogue's Avatar
madpogue
madpogue is offline
Yes, IDMs are interchangeable, '94.5 to '03.
Old 03-22-2016, 09:45 PM
drun's Avatar
drun
drun is offline
Smile
I got my PCM repaired by SIA Electronics (blown resistor), and ran injector buzz test (1 injector buzzed). I got a rebuilt IDM from GB manufacturing. While it was down I cleaned fuel filter bowl and regulator screen and replaced filter. I left my Tony Wildman chip off until he tests it at his shop.
Truck fired right up and is running fine.
Old 03-23-2016, 05:56 AM
CampSpringsJohn's Avatar
CampSpringsJohn
CampSpringsJohn is offline
That's great to hear!
Dan Taylor
09-23-2012 06:37 PM
Rory_Johnson
16
05-31-2009 07:27 AM
ttttmaxx
15
01-24-2009 05:32 PM
jssolari
1999 to 2016 Super Duty
44
01-19-2006 07:27 PM
palajoe
03-04-2005 10:06 AM
Quick Reply: 97 7.3L died on freeway
