OBD1 location a 1995 f250 with the 7.3 Powerstroke diesel
yup, pretty sure. mainly because like is shown in Jose's post above, the EEC-IV, or pre OBD II link is under the hood near the driver side hood hinge, not under the dash.
and the connector under the dash he has plugged into the code reader looks just like the door chime connector in the 97 to 91 trucks.
What to do if my truck is not running?
Thank you for any info, trying to fix truck for Dad and get him off scooter. Just bought Innova 3070RS scanner and getting communication error.
Sorry for any errors regarding posting, 1st timer.
Received 3,090 Likes
on
welcome to FTE!!!
check with your dealer first, a lot of them will not longer reflash a PCM as they no longer have the tools to do it.
and you would have to bring the whole truck to them, they will not do it to a removed PCM.
with that said, there are a few reputable companies out there that will repair/flash a PCM, but it is around $350 last i saw.
8-94 95 f350 crew cab 7.3 What is the best course of action if you want to get pcm flashed by dealer and the truck won't start. Tow to dealer, remove pcm, or give a mechanic a tip to come to the truck?
I am not going to claim that I know the issue or that what is going on with your PCM is what I have seen recently, but I have had THREE 94.5-1995 and ONE 1996 F250s/F350s come in here the last 13 months that have PCMs that will not communicate with scanners and two that would die after a few minutes of running because the internal clocks were drifting. The PCM/IDM, and scanner/flash devices need to run at the same baud rate to convey information and when the clock timing variance becomes too much, everything quits working. This is why this era of 7.3L has such issues with flash programmers "bricking" the PCM.
Finding a compatible 1997 PCM is going to be the long(er) term fix for these vehicles and unfortunately soon, they too will be no good.
thesnowboarder
08-10-2010 01:11 PM
k2vailkid
08-19-2007 11:05 AM
