2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
No start,anti theft flashing rapidly,intermittent problem
Old 04-14-2016, 11:50 PM
k9education's Avatar
k9education
k9education is offline
Originally Posted by Remmons
To catch up,on the latest. They replaced the ignition switch, still stalled. Broke the tilt lever for second time. After all this they replaced start/stop relay #9 in fuse box under hood. So far so good. 4 days no problems. This was after they spoke with ford engineer and was told they only heard of this one other time. Keep your fingers crossed for me.
Let me know what u guys think. Thanks for the help and thoughts.
Four days is a good sign. I hope that's the last of that issue. Keep us posted.
  #32
Old 05-16-2016, 04:52 PM
Remmons's Avatar
Remmons
Remmons is offline
Well it officially has been a month without any more issues. So I am going to take it back here in a week or two to have my remote start put back hope all goes well.
  #33
Old 05-20-2017, 11:10 PM
tanchinhan11's Avatar
tanchinhan11
tanchinhan11 is offline
HELLO SIR!
ANY update on this issue? i have the same problem with my 2007 expedition EB.
  #34
Old 05-21-2017, 08:07 PM
Remmons's Avatar
Remmons
Remmons is offline
After replacing start/stop relay haven't had any more issues, . They had also thought it was a bad bad epc board had it replaced first, but it continued to do it until relay was replaced.
  #35
Old 05-21-2017, 08:10 PM
Remmons's Avatar
Remmons
Remmons is offline
After replacing start/stop relay haven't had any more issues, . They had also thought it was a bad smart juction board had it replaced first, but it continued to do it until relay was replaced.
  #36
Old 05-22-2017, 04:49 AM
tanchinhan11
Actually, I first changed the BCM of the unit and they reprogrammed the key to match the BCM. After a month, this problem occured. Do you think this was the cause of it? maybe they didn't program the key well? or this was caused by something else? is there a possibility that the key looses its program?
  #37
Old 06-04-2017, 12:35 AM
tanchinhan11
update:
my PCM got wet. Anyone knows why it happened? as far as i know, the PCM is sealed.
  #38
Old 07-10-2017, 07:28 PM
docb969's Avatar
docb969
docb969 is offline
Sorry i was slow to find
I would like to thank you guys for your responses. I was informed today that they replaced the ignition switch. I will try to keep you guys informed. Thanks again
I wish I had found this trend before you gone through all this. I own and operate a small shop in northern Michigan.
I had a customer with same problems on a 2000 Expedition. The Ford dealership sends me all there problem child's they can't figure out. Dealer changed out the PCM, ECM, climate control unit and cluster. Here's what we found after extensive going through the whole system. After pulling the wiring harness for the ECM and also the PCM Communication cable we found there was no shorts in that but what we did find was from the steering column. Down in the column runs the wiring harness that has a ground wire that broke and it was caused by the shifter that's in the column. It took us six days to figure out exactly what was happening. We traced every wire on that vehicle from under the dash to the motor housing. We found that it was a manufacturer defect at time of assembly. We billed the dealership 67 hours. Talking to Ford engineering in Dearborn for over 15 hours. They were truly stumped. Good luck with yours.
pahealy59
2009 - 2014 F150
03-18-2018 10:07 AM
slomafarms
1997 - 2003 F150
10-31-2011 11:59 AM
johnday
1999 to 2016 Super Duty
12-03-2010 11:15 AM
missy
1997-2006 Expedition & Navigator
05-09-2009 05:32 PM
Keith1984
Electrical Systems/Wiring
01-13-2006 02:04 PM
Quick Reply: No start,anti theft flashing rapidly,intermittent problem
