1951 F5 Marmon-Herrington
Old 02-03-2016, 10:54 PM
jwhorsefolk
jwhorsefolk is offline
jwhorsefolk is starting off with a positive reputation.
Making progress on the 1951 F5 M-H project. It has a Cotta transmission between the Ford transmission and the transfer case. Apparently, it moved a lot of snow back in the day. I am interested in returning it to original M-H AWD condition. I have not been able to find a diagram of the chassis for a R5-4 M-H. Any help would be appreciated.
Old 02-03-2016, 11:58 PM
CaptPayne's Avatar
CaptPayne
CaptPayne is offline
CaptPayne is starting off with a positive reputation.
That's my 51 F5 M-H I'm working on (minus the yoke out between the trans and aux). Send me a pm with your e-mail address, and I'll send you the PDFs I got from Marmon.
Old 02-04-2016, 03:15 AM
truckdog62563's Avatar
truckdog62563
truckdog62563 is online now
truckdog62563 has a brilliant futuretruckdog62563 has a brilliant futuretruckdog62563 has a brilliant futuretruckdog62563 has a brilliant futuretruckdog62563 has a brilliant futuretruckdog62563 has a brilliant futuretruckdog62563 has a brilliant futuretruckdog62563 has a brilliant futuretruckdog62563 has a brilliant futuretruckdog62563 has a brilliant futuretruckdog62563 has a brilliant future
Here's mine, which is an F-3 but has the same mid-frame layout of the transfer case as does an F-5. I'll see if I can also get a good photo of the R5-4 chassis diagram to post. Getting CaptPayne's pdf will I suspect give you the whole manual, am I correct CaptPayne? Stu
Maybe this will help too. Stu
Old 02-04-2016, 09:11 AM
CaptPayne's Avatar
CaptPayne
Stu, yeah it's the manual, and that lubrication chart is the best chassis diagram I can think of.
Looks like another without the MH PTO... Dang
Old 02-04-2016, 09:26 AM
truckdog62563
Yeah, I've never seen one of the transfer case PTOs. Josh has one on his F-2 M-H, so maybe he'll post a picture. Owen (1952henry) told me a story years ago of finding a M-H with a PTO in an Oregon yard. It was on a big truck and he didn't think at the time it was right for his truck. But we now know from Chuck and the manuals that all of the F-2 / R32-4s through the "V" series F-6s used the same Fuller or Wisconsin transfer cases. That yard PTO could have been golden. Stu
Edit - here's the transfer case from the other side showing the big mounting location. The PTO must be huge. Stu
Old 02-04-2016, 03:59 PM
1952henry's Avatar
1952henry
1952henry is offline
1952henry has a good reputation on FTE.1952henry has a good reputation on FTE.1952henry has a good reputation on FTE.
The yard was out west and the truck was an f800. Been a few years but when I last checked most of the larger, older trucks were gone. Imagine it is part of several turdotas or crapsuns now.
Old 02-04-2016, 04:14 PM
truckdog62563
I didn't remember it being an F-800. Probably not the same transfer case I guess. Maybe a little less than golden. Stu
Old 02-06-2016, 08:00 PM
jwhorsefolk
Hey Guys, thanks much for the photos and diagram, they were very helpful. We seem to have most of the pieces to the puzzle, and we know where they fit. Since the Cotta transmission is coming out, does anyone have an interest in it? The Stock List is RS-200, Model RS, Serial #72980.
Old 02-07-2016, 09:56 AM
38 coupe's Avatar
38 coupe
38 coupe is offline
38 coupe has a great reputation on FTE.38 coupe has a great reputation on FTE.38 coupe has a great reputation on FTE.38 coupe has a great reputation on FTE.38 coupe has a great reputation on FTE.38 coupe has a great reputation on FTE.
I am curious about the Cotta transmission. I am interested in the smaller size vintage auxiliary transmissions. How big is this one? Do you know what ratios it has? Can you post more pictures of it and how it is mounted?
Thanks,
Fred
Old 02-07-2016, 11:01 AM
truckdog62563
Chuck has described this as an "under drive" gear box, which I guess would be like a torque multiplier needed to deal with snow removal. What other application would it be suited for? Stu
Old 02-17-2016, 08:13 AM
40fordmarmon6x6
40fordmarmon6x6 is offline
40fordmarmon6x6 is starting off with a positive reputation.
Changing gear ratios for hyway speeds
Sorry to bother but I can't seem to pm you for some reason. I am also interested in any marmon herrington info especially driveline related. What are these pdfs you speak of? Mine is a 1940 6x6 ex crash tender ford that I am putting back together. If you could send them to me i would greatly appreciate it. [email protected] or rosscometals.com
Just my two cents but has anybody tried changing/making new gears for the transfer case?
Old 02-17-2016, 08:32 AM
truckdog62563
Every M-H model had a printed Maintenance and Parts Manual. CaptPayne and others have had success getting a pdf version for their model directly from M-H. I've got paper copies for mine and a few related models but have never attempted to get a pdf from M-H. You might contact their Customer Service Dept to see if yours is available. Stu
Old 02-17-2016, 04:36 PM
1952henry's Avatar
1952henry
f
Are you trying for greater top end speed? If so you would have to have the gears made to overdrive rather than direct drive the transfer output. Seems it would be a whole lot less expensive to put in a Brownie with overdrive.
Old 02-17-2016, 05:55 PM
40fordmarmon6x6
Brownie? Damn now I'm hungry.
Originally Posted by 1952henry View Post
f
Sorry, you'll have to excuse my ignorance. I am unfamiliar with this brownie you speak of.
Old 02-17-2016, 06:14 PM
1952henry's Avatar
1952henry
Perhaps Fred Mills will chime in with some specific options. For now, in a nut shell, a "Brownie" was an auxiliary transmission that was mounted aft of the main transmission giving you more gear options. Large ones gave you up to four extra gear choices. Perhaps you have heard of older trucks with 5x3 or 5x4 transmissions. That meant 5 speed main box and 4 speed brownie or auxiliary. They are kind of fun to drive, but a bit more involved than say an 18 speed.
Anyhow with Fred's knowledge on these, he could help you choose a brownie that you could mount between your transmission and transfer case that would provide overdrive. Some new gear box mounts and relocation of others, along with driveshaft modifications would be in order. Still probably cheaper than custom gears in an obsolete transfer case.
Nice find btw. Keep us posted, you have fellow M-H fans here.
Quick Reply: 1951 F5 Marmon-Herrington
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
