1951 F5 Marmon-Herrington
Sorry to bother but I can't seem to pm you for some reason. I am also interested in any marmon herrington info especially driveline related. What are these pdfs you speak of? Mine is a 1940 6x6 ex crash tender ford that I am putting back together. If you could send them to me i would greatly appreciate it. Chadptrs@gmail.com or rosscometals.com
Just my two cents but has anybody tried changing/making new gears for the transfer case?
The PDF's I have are specifically for the R6-4 model. I lucked out when I called them as they have one restored in their showroom apparently that had most of the documentation. Give them a call and explain what you are after and they will help you as much as they can. Didn't seem like they had too much information on stuff from back then anymore. Really wish they still did some medium duty stuff, as I'd kill for front disc brakes on a newer axle.
BTW, nice to see another Canuck with odd old metal like this too. If I ever get back east again might have to pop by.
Cheers,
Mike
Perhaps Fred Mills will chime in with some specific options. For now, in a nut shell, a "Brownie" was an auxiliary transmission that was mounted aft of the main transmission giving you more gear options. Large ones gave you up to four extra gear choices. Perhaps you have heard of older trucks with 5x3 or 5x4 transmissions. That meant 5 speed main box and 4 speed brownie or auxiliary. They are kind of fun to drive, but a bit more involved than say an 18 speed.
Anyhow with Fred's knowledge on these, he could help you choose a brownie that you could mount between your transmission and transfer case that would provide overdrive. Some new gear box mounts and relocation of others, along with driveshaft modifications would be in order. Still probably cheaper than custom gears in an obsolete transfer case.
Nice find btw. Keep us posted, you have fellow M-H fans here.
Leichardti
Electrical Systems/Wiring
16
06-29-2015 10:24 AM
Caper10
02-08-2005 05:26 AM
1explorer
06-18-2002 08:10 PM
