General Diesel Discussion
6.5 Detroit into a 96 f150
Old 02-03-2016, 10:24 AM
96f150windsor's Avatar
96f150windsor
96f150windsor is offline
I am new to this site. I am pretty well new to forums in general, but I am desperate for some help.
This upcoming few weeks my dad is going to be getting a 95 Chevrolet dually with a 6.5 Detroit in it. The guy that owned it before put a newer engine in it from a wrecked truck. My dad is planning on giving me the swapped out 6.5. I've always wanted to put a 4bt in my f150 but this is the perfect opportunity for something bigger.
If someone could help me get some parts lists together and some "instructions" for the swap, that would be fantastic. I'm planning on starting around April and attempting to finish be August.
Old 02-03-2016, 05:08 PM
lee00's Avatar
lee00
lee00 is offline
Why?
Judging by the list of issues 6.5ls exhibit on wikipedia...I would almost classify them as the gm version of the 6.0L
https://en.wikipedia.org/wiki/Detroi...V8_engine#6.5L
Old 02-03-2016, 05:39 PM
96f150windsor
Because I have the engine already, I'm on a budget, and I want to.
Old 02-03-2016, 05:40 PM
96f150windsor
And I also have a list of problems and solutions that I can fix while it's on a stand.
Old 02-03-2016, 09:57 PM
85e150's Avatar
85e150
85e150 is online now
Received 1,579 Likes on 1,288 Posts
Not a good reason--already having the engine that is.
You will probably break any budget you set for this.
There are no "instructions" for this swap.
You are converting a gas to diesel, so you are looking at fuel, cooling, exhaust, engine mounts, cross members, oil pans, transmission, gauges,
Which version of the 6.5 do you have?
What's in the '96 now?
I will be thrown off the site for saying this, but there are some GM motors worth swapping into another make, but IMO this ain't one of them.
Old 02-04-2016, 06:42 AM
lee00's Avatar
lee00
lee00 is offline
^what I was thinking!
As I recall most early gm diesels were considered under powered....
You forgot to mention Brakes, suspension, tires, drive train (drive shaft, u joints, rear end, axles). None of that in an f-150 was meant to handle that kind of power...
Old 02-04-2016, 08:38 AM
tjc transport's Avatar
tjc transport
tjc transport is offline
i ain't rite
Received 3,081 Likes on 2,151 Posts
this site is for helping people that want help.
the guys so far have given you good advice, whether you want to use it or not is up to you .
to put that engine in a F-150 you are going to have to re engineer EVERYTHING.
and you will still have a truck with an at best problematic engine that you will not be able to get parts for if you break down on the side of the road, and no one will want to work on if you can not fix it yourself.
Old 02-04-2016, 09:10 AM
rufushusky's Avatar
rufushusky
rufushusky is online now
Swaps and budget generally don't belong in the same sentence. A B series Cummins swap can easily run from $5-$15k depending on a multitude of things. That even takes into account the massive amount of support that set up gets. If you do want to get an idea of what you are going to need check out destroked.com. He might be able to fab up a transmission plate adapter, flywheel etc if your keeping the ford trans. Of course if your keep the chevy trans then your going to need to work out the drive line issues (shafts, u-joints, transfer case etc) and make the Ford linkages and what not work with the chevy hardware. In addition to the fabrication work on the motor mounts, fuel lines etc etc.
I highly doubt you are going to find any instructions or how to's on swapping a 6.5 into a Ford. You are venturing into a bit of uncharted waters, good luck on the project.
Old 02-04-2016, 09:34 AM
Maxium4x4's Avatar
Maxium4x4
Maxium4x4 is online now
Received 3,373 Likes on 2,076 Posts
The 4BT in your first post is the better idea, sell off the 6.5L and use the funds to buy the 4BT. Speaking from experience, the 6.5 Turbo Diesel GM used is a dead end.
Old 02-04-2016, 10:04 AM
96f150windsor
Thanks man! Much appreciated.
Old 02-04-2016, 10:38 AM
96f150windsor
Comments deleted by Maxium4x4
Old 02-04-2016, 10:58 AM
lee00's Avatar
lee00
lee00 is offline
Moderated
That's the job of the moderators on here. Respect their authority, they have kept this a civil place for years, especially considering the volume of posts daily.
Old 02-04-2016, 11:31 AM
96f150windsor
Alright, alright.... I submit lol. Anyway, you guys have a wonderful day! Thanks for the replies and the advice. I will take it all into consideration and maybe post some pictures if this actually goes through.
Old 02-04-2016, 12:21 PM
lee00's Avatar
lee00
lee00 is offline
We LOVE Pictures!
Old 02-04-2016, 12:32 PM
tjc transport
i ain't rite
Originally Posted by lee00
We LOVE Pictures!
yup, we even have a picture to show how much we love pictures:
Quick Reply: 6.5 Detroit into a 96 f150
