1956 F100 Replacement Cab Corners
I bought replacement cab corners and they seemed ok until I went to install them. These stampings were from Mid-Fiftys and are quite a bit off. Has anyone come across this and did you just massage them into shape or leave as is?
Ernie
The original has a sharp bottom and the replacement is a lot more rounded.
The bottom width is a lot wider on the replacement.
I guess it's a good thing these aren't visiable once the bed is on.
Ernie
The patch panels are lousy. Everyone says they're stamped from genuine Ford machines but that obviously can't be true. The door patch panels for the inside of my '56 were awful. Everything was at least a half an inch off. It's discouraging a know. And yes you have to work with what you have. Try finding someone with an English Wheel and firkle away. Whatever the heck that means.
When I did my 56 I got cab corners from mid fifty and tried to put them on. They did not fit worth a crap. The bottom corner was not the same shape as the original cab corner. The only thing that was close was the door jam area. I wound up getting a set of Schott corners and they fit but the door jam was not right. I had to alter that part to make them work. I also used the Mid Fifty inner cab corners which fit well but again needed minor tweeking. I am in the market for another set of Schott corners for my 56 COE.
Here's the disclaimer from Mid Fifties Site:
Patch panels are not covers, they replace the original sheet metal, however, like all repair pieces, they may not be exact duplicates of original. Even original cabs are not all exactly alike as they were not all stamped from the exact same dies.
Looks like it's time to bring out the firkling hammer and beat some shape into them.
brucelee
01-23-2018 02:33 PM
meangreen92
10-19-2017 02:05 PM
march
08-25-2017 07:28 PM
71mach351
03-16-2011 09:58 PM
