7.3L PIDs for 2016 - Torque Pro and others. - Page 5 - Ford Truck Enthusiasts Forums
Go Back  Ford Truck Enthusiasts Forums > Diesel > 1999 - 2003 7.3L Power Stroke Diesel
Reload this Page >
  #61
Old 05-31-2016, 10:50 PM
Colorado Horseman's Avatar
Colorado Horseman
Colorado Horseman is online now
Colorado Horseman has a good reputation on FTE.Colorado Horseman has a good reputation on FTE.
I have a 9 pin UVCH test rig and ohm all glow plugs @ 0.7.
Injectors #2 and #7 ohm high - 7.2 and 10.6. Others @ 4.5.
Same high ohm injectors show weak on buzz test.
NO CODES, mil lamp should come on for electrical fault. Miss on one or two cylinders till EOT over 130*.
My next option is to pull valve covers and check for bad connections or UVCH?
Kind of guess at bad solenoids #2 and #7 or poppet valves worn and decreasing armature clearance.
Your best guess?
  #62
Old 06-01-2016, 07:31 AM
Tugly's Avatar
Tugly
Tugly is offline
Tugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputation
Classic loose UVCH under both covers. When you pop the top, you will find each of the UVCHs loose on the left side as you face them.
  #63
Old 07-13-2016, 08:36 AM
Tugly's Avatar
Tugly
Tugly is offline
Torque Pro has a new feature I discovered after some updates. It took my Turbo Differential Pressure and declared it a "Virtual Gauge" - which it is. A virtual gauge is when a person takes a real gauge and blends it with other inputs to end up with a gauge not otherwise available. With a great big formula that includes a ton of PIDs, one could go so far as to come up with a pretty accurate live MPG gauge. Torque shows the virtual gauge as an icon with a different-colored background from the "real" gauges. This means I can look at the list of PIDs available when adding a gauge, and immediately spot the virtual gauge I created.
  #64
Old 07-13-2016, 10:28 AM
timmyboy76's Avatar
timmyboy76
timmyboy76 is online now
timmyboy76 has much to be proud oftimmyboy76 has much to be proud oftimmyboy76 has much to be proud oftimmyboy76 has much to be proud oftimmyboy76 has much to be proud oftimmyboy76 has much to be proud oftimmyboy76 has much to be proud oftimmyboy76 has much to be proud oftimmyboy76 has much to be proud of
^^^...i noticed this as well with MFD
  #65
Old 07-30-2016, 11:01 AM
Victorthe1
Victorthe1 is offline
Victorthe1 is starting off with a positive reputation.
Tugly, i would be so appreciative if u could re up ur .cvs file its no longer available . Ur literally the reason i joined this forum, ive been messing with torque app trying to get it to accurately measure boost with no luck . It fires up at like 14.5 and im stumped. Jus wanna delete what i have and put ur .cvs file n to give it a last go
  #66
Old 07-31-2016, 08:58 AM
Tugly's Avatar
Tugly
Tugly is offline
I have been contemplating doing the 2016.5 TP thread soon, but I am still in working weekends mode (including yesterday). I "smell" a lull coming up soon, so I may be able to get the thread and my whole gauge profile up this month. Once I get this up, it should be on there permanently - the last one was from a volunteering member, and his file location may have expired.
  #67
Old 07-31-2016, 04:03 PM
jeronlines's Avatar
jeronlines
jeronlines is offline
jeronlines is gaining momentum as a positive member of FTE.
subscribed
  #68
Old 07-31-2016, 05:10 PM
Victorthe1
Thanks a ton tugly!
  #69
Old 08-01-2016, 06:44 AM
Tugly's Avatar
Tugly
Tugly is offline
I take it you programmed both the BARO and the Boost PIDs? You only need to display the Boost gauge, not both.
Long name:Barometer
Short name: BARO
PID: 221442
Max/Min: 15.0/10.0
Unit: PSI
Equation: ((A*256)+B)*0.03625
Header: C410F1
Boost
(AKA Manifold Gauge Pressure)
Short Name: Boost
PID: 221440
Units: PSI
Max/Min: 30.0/0.0 (stock) 40.0/0.0 (performance)
Equation: (((A*256)+B)*0.03625)-[221442]
Bear in mind, the boost will just meander around the little numbers until you step up (or down as it is in this case). It takes real throttle to get that boost to prairie dog. If the boost still doesn't climb after you have entered the formula above and added throttle, you may vary well have a disconnected or leaking MAP line, some real bad boost leaks, or a toasted turbo. Does the truck make a lot of black smoke smoke?
  #70
Old 08-01-2016, 07:36 AM
Jaime74656's Avatar
Jaime74656
Jaime74656 is offline
Jaime74656 is a splendid one to beholdJaime74656 is a splendid one to beholdJaime74656 is a splendid one to beholdJaime74656 is a splendid one to beholdJaime74656 is a splendid one to beholdJaime74656 is a splendid one to beholdJaime74656 is a splendid one to behold
do you feel the torque pro FAQ should be updated also?
  #71
Old 08-01-2016, 07:45 AM
ExPACamper
ExPACamper is offline
ExPACamper has a brilliant futureExPACamper has a brilliant futureExPACamper has a brilliant futureExPACamper has a brilliant futureExPACamper has a brilliant futureExPACamper has a brilliant futureExPACamper has a brilliant futureExPACamper has a brilliant futureExPACamper has a brilliant futureExPACamper has a brilliant futureExPACamper has a brilliant future
IIRC the latest versions of Torque Pro has BOOST as part of the extended FORD POWERSTROKE PIDs. It's listed as MAP.
Add that gauge and then you can rename it to BOOST if you like
  #72
Old 08-01-2016, 09:29 AM
michaelg10
michaelg10 is offline
michaelg10 is gaining momentum as a positive member of FTE.
Yes, boost is there.
I just started using the OBD MX bluetooth adaptor and a GooglePlay "hacked" Kindle Fire tablet with TorquePro that is working great, however I am unable to load my log files to the webserver. Frustrating to say the least.
  #73
Old 08-01-2016, 10:00 AM
schlepprock250's Avatar
schlepprock250
schlepprock250 is offline
Guns Dont Kill People..
schlepprock250 is a splendid one to beholdschlepprock250 is a splendid one to beholdschlepprock250 is a splendid one to beholdschlepprock250 is a splendid one to beholdschlepprock250 is a splendid one to beholdschlepprock250 is a splendid one to behold
OT .. High jack coming up. I have a Fire tablet that I hacked/rooted as well. So I could add my own apps.
  #74
Old 08-02-2016, 12:32 AM
Victorthe1
Tugly i entered ur boost pid there, i have several baro pids loaded.one matched the one u provided. So ill give it a go tomorrow after work. No black smoke. blows alittle blueish smoke when i fire it up after its sat over night
  #75
Old 08-02-2016, 07:43 AM
Tugly's Avatar
Tugly
Tugly is offline
Things change fast in the app world - plus we are collectively learning new things at a good clip. I am finding enough differences about every 6 month to warrant a refresh of the thread. I spotted something important lately: The correct formulas are being learned by enthusiast of other Ford vehicles and they are being shared - many are in line with what I learned earlier, but a few have gone beyond what I experimented with because of my time constraints.
The trick to grabbing something from a list of multiple same-named PIDs is to have it identified by the short name. The long name cannot be change without "ruining" the PID, but the short name is fair game.
Many of us have the same OBDII adapter and vehicle, but the portable devices are way too variable - particularly when hacked. You might have better luck on a Kindle forum with a question of this nature - many there have a wide variety of vehicles and are doing exactly what you want to do with TP.
Quick Reply: 7.3L PIDs for 2016 - Torque Pro and others.
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
