7.3L PIDs for 2016 - Torque Pro and others.
on
It is bluetooth connection not WiFi.
I will go outside now and try to start the truck with OBDLink plugged in and not running TP.
When you say delete PID's should I delete all or just the custom ones I entered from Tugly's list above?
Edit: Truck fired with OBDLink plugged in and without any Android devices around.
Depending on what you have done with it, you might be better off to uninstall and reinstall TP, then connect with RPM as the only PID. Make sure the installation and stuff is okay.
Then add maybe 2 or 3 PIDs at a time and test in between.
Hopefully that will get you going
Also, when I entered the PID's from Tugly's list I never hit the test button as I did them inside I just hit the enter button. If that means anything.
I will go ahead and uninstall TP and try it again with just RPM's. I remember a while back when I was on the phone with Rich he said to delete the PID's that have nothing to do with our 7.3, like delete coolant temp and FICM.
on
I left some of those installed (from TP's custom PID list for Ford), since I do run it on different trucks as needed
It says OBDLink with a bunch of numbers and some decimal's in it.
That being said... the cheap clone bluetooth devices frequently have a cloned MAC address. This is not to say the cloned MAC address will collide with other legitimate bluetooth devices in the truck, like phones and wireless microphones - but it can collide with other cloned OBDII adapters in close proximity (like next to you at a traffic light). When using a cloned OBDII adapter, it is remotely possible others can hack into it from outside the truck - by using a known-cloned MAC address. Electric door locks? Trying to use a $20 cloned OBDII adapter may very well be handing nefarious folk a key to the truck.
Critical Note: Please read this first!
Never ever add a gauge while connected with the engine running... no matter how the PID came to you. The data can have an error or a typo in it, so it's best to set up your gauge off-line, then connect to the truck KOEO after everything is set correctly (to the best of your knowledge), then click "test" in the custom PID configuration menu. No data or the truck freaks out? Well... don't put that on your gauge page for sure - until you get a successful test.
Hahaha, I read that 5 times making sure I didn't do the exact opposite as usual! I was sitting inside far away from the truck with your list on the computer and added 1 by 1 to the tablet. After each custom PID that was entered near the bottom was 3 options Cancel, Test and Enter. I hit test but a little screen pop up said must be connected to the ECU, so I just hit Enter and continued onto the next PID. My question was, if not hitting "TEST" does that not log the PID correctly.
You can add a PID without testing, and you can save it - even if it fails the test. Just prepare to log onto the forum and post the following: "...so I went to fire up the truck and nothing just cranks."
I have several instances of PIDs named the same. I tried changing the names on them to make them unique and it was a total fail - they did not pass the test button. What we are left with is to choose only one option for each PID name and roll with it. I chose the Turbo Delta option under Exhaust Back Pressure - far more telling than trying to compare EBP and MAP. I use this as my Filter Minder.
Thank you Sir.....I will do the same. Getting this all set up so I can get some good readings as I'm getting a surging at idle and trying to maintain highway speeds....beginning the trouble shooting process. I will start a new thread once I get some base line info.
Well sorta back to square one......installed all the custom pid's and only 3 of them work, the rest have no response. But when I was messing around in there I noticed they already had pid's setup for the 7.3l powerstroke, I installed them and they worked but the names are off from yours I will have to compare them and see if I can rename the short name so I know for sure what they are
#29
#30
