Engine Rebuild Part 2
#556
Rockers en route. PM sent.
interesting thought on the deflectors. they look like a fomoco product rather than an "off-the-shelf" part from summit or jegs. Anyone have a part # for these by chance?
Sorry for the hijack.
One thought I had. What about oil deflectors? One thing I noticed when I was running the engine with the valve cover off is how often the oil would shoot over the rocker, even at idle. Yeah, the rockers are full of oil, but maybe it's not enough?
Something like these?
#557
Thank you, much appreciated. I'll keep an eye out for them, swap them in, and report back. These grooved rocker arm ***** took about a week and a half before the squeaked, so I won't know right away. But, I'll definitely keep you posted.
As for the oil deflectors, they're worth a try. However, it's interesting that I see them on quite a few pictures of rocker arms (looking stock) but whenever I look them up on parts sites, they're listed as being used to deflect oil while you're adjusting your rockers with the engine running, and keeping the oil from splattering all over. Not necessarily a permanent thing.
#558
#559
#560
So.....
Things have slowed down.
My wife and I had a bomb dropped on us when she was diagnosed with cancer two weeks ago. Lots and lots of doctors appointments and very little of anything else.
It's been crazy, and I'm pretty overwhelmed at the moment.
Fortunately, we think we caught it early, so it's just going to be a few months of treatment. But, yeah... Thoughts and prayers are gladly welcome.
As for the engine, I installed the rocker arms you sent me, Dude, and have just been putting some miles on them to see if they start squeaking. There were 3 of the 12 that I didn't want to put on due to excessive wear, so I put 3 of my originals on.
When I had all 12 of them on there, there was no chirping at all, When I took those 3 off and 3 of mine on, there was some chirping right away.
I'll probably pull the valve cover this weekend and have another listen. Hopefully, the chirping is still only coming from my original 3, and not some of the "new" ones. If so, then I think I just got some bad rocker arms and I'll buy all new ones. If some of the OEM Ford ones are chirping, then I'm kind of at a loss as to what to do next.
Otherwise, the engine is driving really nice and has been a lot of fun. It has great power, and the more I get the carb dialed in, the low RPM power just gets better and better. I'm happy with it.
#561
So.....
#565
Thank you everyone, I appreciate it. Can use all the support we can at the moment. It's.... insane.
On the Bronco, my test looks to be a success. I pulled the valve cover this morning and ran it. The stethoscope was great at finding which were squeaking. It was over the top obvious since off they weren't, there was just a healthy little tick. If they were, the sound was almost painful in my ears it was so shrill.
Well, the only 3 that were squeaking were the three from the set I bought. The OEM ones were nice and quiet. TheDudeAbides, thank you so much for those.
So, I think I just got some bad rockers. I swapped them out until I found three that didn't make any noise, so it's nice and quiet now! I'll still still get new rockers since these have high miles on them and I don't want the worn tips hurting my valve stems, but at least I know what it is.
#566
#568
And yes it does, this is not someone either of us expected to be dealing with. I'll be sure to update.
That He is, my friend.
#569
Another addition to your conundrum with the rockers...the head in my truck is a later pedestal mount head. I swapped the cam, timing gears, pushrods and put all new rockers, pivots and hold-down bolts into it early this spring. Recently developed a lot of valvetrain noise...no crickets on steroids...but it wasnt the normal clack of a 300. i swapped back to the originals that were in it prior to the cam swap. All is right in the world, and the rocker noise is no longer offensive now. Strange coincidence.
#570
I'm curious what makes a good rocker arm from a bad one when you can't visibly see the difference. Maybe the curvature of the socket isn't perfectly round? Different metals that aren't hard enough? Dunno.
Well, I pulled the trigger on a set of Comp rocker arms. With the way things are going right now, the cost of roller rockers was just too much at the moment. They seem to be really nice quality. Also, the slot, as advertised, was a bit longer. Not a crazy amount, but noticeable. Comp on left. Ford OEM on right:
I installed them yesterday and had instant relief from the squeaking and chirping. Still a bit of "diesel" clack, but I don't mind it. On a mechanical level, I am really curious where it comes from though. Is it the valve making contact with the head again?
Either way, only time will tell if these will work. The original ones I had didn't start chirping until there were about 100 miles on them. Hopefully not! (If so, I'll send them back to Summit). But if they work, money well spent. I'll keep you all posted.
