brakes/steering, excursion vs f350
so, given both trucks are stock (my excursion is an 01 v10 4x4, and my f350 is an 04 6.0L 4x4 CC dually long bed), what are the differences in the steering/braking components? i think someone told me once that the steering is different on the 2 trucks, but not sure about brakes. i've driven other excursions, but never really driven other dually or Super duty trucks at all other than mine. the steering on my dually is WAY harder to steer. i mean it requires A LOT more effort than the excursion does. the excursion is 10x easier to just relax while driving, the dually just requires so much more effort. i still love the truck, but damn, comparing the 2, sometimes ill take the excursion if i'm tired because i don't feel like steering the thing! now braking, the dually brakes way easier than my excursion. my dads excursion is the same way as my excursion, it seems like when you brake, the dash shakes a lot. the faster you were going (harder you use the brakes), the more it shakes/vibrates. my f350 brakes seem way more...whats the word...i guess...sturdy? can't think of the word, but it stops a lot better.
just looking for some comparisons from guys that own/have driven both trucks.
I think what's going on is that you have a problem with the power steering in your F-350, and a problem with the brakes on your Excursion.
My truck brakes and steers without issue.
Is the shaking due to warped rotors or do you have cheap pads? I switched to EBC yellow stuff pads and Napa premium rotors and I have strong, smooth brakes now. It really made a big difference.
hmm...ill have to get a video of my excursion when braking hard. my dads has done it since he's had it also, which is nearly since new (1 year old) as long as i can remember. his is always loaded down with tools though, mine is empty. they sorta just shake when braking hard, and since his does it, i figured it was normal. i will take a video.
pirate, you have an excursion right? comparing the 2, the steering, i guess the word would be..."tension" or resistance, felt the same? they def don't comparing my excursion or my dads excursion, to my 04 f350. while driving around, if i see a similar dually truck at a dealer for sale, i will stop in and test drive it. ill just tell them i want a second one. LOL
Here is a very good article that explains the issue in detail: -Warped- Brake Disc and Other Myths
And here's a good summary:
Interesting article, but the guy sure seems to go out of his way to make the concept complicated.
My interpretation:
- rotors don't warp, they just have their thickness affected by built-up (sometimes invisible) pad material - which has the same effect as warping
- rotors can be permanently altered (via cementite) by excessive heat - which again has the same effect as warping
Bottom line: rotors have a bunch of crud build up on them that makes them seem like they're warped.
I'll try the garnet paper idea. Thanks.
My interpretation:
If you thought the dash shaking while braking was " normal" then why did you bring it up here?
Invest in some good quality brake parts and fix the problem, the shaking dash is the classic sign of rotors being out of true, either warped, loaded with deposits or damaged in some other way. No vehicle should shake under hard barking.
If these statements are all true, then I don't understand how the following:
Can also be true.
It's a common problem with cheap aftermarket brake parts, which is why you have it on both trucks. What do you mean by "the rotors are fine"? Have you had their thickness measured with a micrometer? Have you had the runout checked? Have you determined if the vibration coming from warped rotors or cementite deposits on the surface of the rotors, which generally comes from using cheap pads?
Can also be true.
on the statement in the very top of your post about the steering. i see how it looks like i contradicted myself by saying it doesn't feel broken. but what i mean is, i've felt a truck, hell even a small car, with the power steering completely broken. it's nothing like that, all i'm saying is comparing the excursions to my f350, it feels like theres a stronger resistance on my dually, be it steering in place, moving, pavement, dirt, etc. testing both trucks in the same situation...yea.
maybe this will put things into perspective. if i put my f350 in 4lo, and drive in my back yard, and drive my excursion on the same terrain, but in 2wd, when the dually is in 4lo, it makes it a lot easier to turn the steering wheel (obviously) but my point is, in 4lo, its more comparable to the excursion in 2wd. i could have sworn i made a thread or a post somewhere once when i first got my dually 4ish months ago, and someone said the steering box/components/something was different on the 2 trucks.
i guess the only way to really find out if this is just how it is and im just a weakling, is to go find a similar SD truck and test drive 1, 2, maybe 3 trucks, and compare them to mine. i understand its a super heavy truck, maybe the diesel vs v10 motor (not sure the weight difference)???
at the end of the day, the world isn't going to end, just trying to figure out what's what.
ive read a little about hydroboost, i thought all superduties had it including excursions. if not, and my f350 has it, maybe that's one of the reasons?
