Dash and gauge swap
Dash and gauge swap
So my good ol f150 didn't come with a tach but I installed a cheap aftermarket one that broke. So I was on the Craigslist yesterday and found a blue dash that matches mine and isn't broken but the gauge cluster is included and it has a tach. So is it possible to use the gauge cluster with the tach or not? I can drive it without its just nice to know the rpms.
Yes, just try to get a cluster from a truck close to, or the same year as yours. Certain years had some slight differences to the way they are wired.
Installing An OEM Tachometer In A 1992-1996 F-150 Or Bronco - Ford-Trucks.com
Each of the instruments can be pulled out of the cluster separately. The temp, oil press, speedo...all come out. So you can keep your speedo when installing the new one.
My truck started without a tach but I added it - Imgur: The most awesome images on the Internet
What year is the truck?
If it's a 87 to 91 you can swap the cluster into your truck, BUT the ole mechanical speedo will not be swap-able between tach and non tach clusters as non tach speedo is wider than the tach speedo.
If yours a 92 and up truck, then as long as its:
92 to 93 plug and play
94 to 95 plug and play
96 to 97(hd trucks only) plug and play
You can then swap out the speedomter(PSOM) between the tach and non tach clusters.
No there is not a 100% way to tell.
I just when down and checked a stack of clusters I have and this is what I found out.
For example the clusters printed circuit out of my 1994 F53 titled 1995 has a F2 on the printed circuit.
Another cluster I have is out of a 96 F250 and that printed circuit does start with an F6.
Another cluster from a 1995 F150 cluster printed circuit starts with an F4.
Received 3,103 Likes
on
as long as you get the proper part it will not mater.
86 and older. 87 to 91. and 92 to 97.
it is pretty easy to see what you are getting, as all three are different.
pre 86 looks like this:
Ford 1980 Truck F150 Bronco Dash Cluster Gauges Speedometer 1981 1982 | eBay
87 to 91:
1989 1990 Ford F150 F250 Truck 6K Tach Speedo Cluster | eBay
92-97:
1992 93 1994 1995 96 FORD F150 F350 F250 BRONCO GAS GAUGE CLUSTER WITH TACH XLT
87 to 91:
92-97:
Now I just looked on Ebay,
92 93 94 95 96 Ford Bronco F150 Speedometer Instrument Gauge Cluster wth Tach | eBay
Found one with the correct board number, but you can see the actual part number was different.
You mention the board number, so this would be the right cluster.
eatont9999
02-03-2012 12:33 PM
