SD to MAF Conversion
Old Mar 6, 2016 | 05:58 PM
Ianator's Avatar
Ianator
Thanks! I just found the plug for the MAF and I think I'm ready to start tearing into it. But before I do I just want to be 100% sure I'm understanding this right. Will following this list will give me the correct firing order? And I just cut out the injector portion of my trucks harness and wire the MAF and injector portion of this harness directly to the plug for the PCM?
Old Mar 6, 2016 | 06:11 PM
Ianator's Avatar
Ianator
I also have 2 wires for each injector plug, where do the other 8 wires go and the MAF has 4 and I only see 3 on the list, is the other a ground?
Old Mar 7, 2016 | 10:58 AM
RIKIL's Avatar
RIKIL
If you got a harness from a mustang, it should have the wires for the MAF to the ECU connector. I would take those wires out of the ECU connector, then get a MAF pigtail and splice it in.
Old Mar 7, 2016 | 12:32 PM
Conanski's Avatar
Conanski
Not in '88, that year was a unicorn with sequential SD.. no MAF meter.
Old Mar 7, 2016 | 12:41 PM
Conanski's Avatar
Conanski
Here is a link for the Mustang wiring harness pinouts at the EEC connector with more detail and wire color codes.. just found this and it looks pretty good.
http://r.search.yahoo.com/_ylt=A0LEV...TJhS6SNFcCvJQ-
Old Mar 7, 2016 | 06:31 PM
xlt4wd90's Avatar
xlt4wd90
That's true for all 1988 Mustangs outside of California. 1988 California Mustangs with the 5.0 engine were the first to get MAF.
Old Mar 7, 2016 | 06:50 PM
Blurry94's Avatar
Blurry94
Have you tried to start it with speed density just to see how it will run?
Old Mar 7, 2016 | 08:44 PM
Ianator's Avatar
Ianator
I found a " '92 " marked on the back of one of the plugs on the harness, so I'm not sure how true the info from the CL parts guy was
I cut that one up and made and injector and MAF harness to be pined into the PCM. I'm still not sure what needs to be taken out of the existing truck harness.
I have started and ran it with the factory SD. It runs and idles OK in park but it won't do
Old Mar 7, 2016 | 08:48 PM
Ianator's Avatar
Ianator
I have started and ran it with the factory SD. It runs and idles OK in park but it won't do any more than idle or just above in gear. No power at all, kinda sounds and smells way too rich, but no smoke.
Old Mar 7, 2016 | 08:56 PM
Ianator's Avatar
Ianator
Here's a link to a video on MAF Conversion that I found pretty helpful.
https://youtu.be/mnnTgXkHU9Q
Old Mar 9, 2016 | 05:35 PM
Conanski's Avatar
Conanski
You don't really need to remove anything from the truck harness, when I did my '90 I cut off all the factory injector connectors but you could just put them aside too, everything else gets reused.
Old Mar 12, 2016 | 11:35 PM
Blurry94's Avatar
Blurry94
A little more engine info would be helpful...what are the specs on the 'RV cam', and the FR heads?
The first thing that grabs my attention to the fact that it will only idle is the over-sized throttle body.
Old Mar 13, 2016 | 02:47 PM
  #28
Ianator's Avatar
Ianator
Ok so I have everything installed and I tried to start it. It just cranks over and won't fire and the fuel pump runs with the keys off. I uploaded this picture of how I repinned the connector for the PCM.
Also the #9 pin for the MAF return was supposed to be empty but it wasn't. I unplugged the pin that was there and taped it off and put the MAF return there.
Any ideas on what I might've done wrong, or what could cause the fuel pump to run all the time, or what was in the #9 spot, or another spot for the MAF return?? I'll be here pulling my hair out and staring blankly at the connector, thanks guys!
Old Mar 13, 2016 | 03:23 PM
  #29
RIKIL's Avatar
RIKIL
that sounds like your bin is not loaded on your tuner or you have the incorrect bin loaded.
Old Mar 14, 2016 | 10:06 AM
  #30
Ianator's Avatar
Ianator
Im sure this is a dumb question but How do I check or load the correct one?
