So my wife was driving my EX today...
and she heard a noise and then the truck would barely drive. I went and checked it and i lost the exhaust pipe between cat and muffler (right below the second row) I also found 4 bared wires that had been ripped apart.
Exhaust broke loose and wrapped around drive shaft and ripped the sensor wires apart and threw the pipe somewhere?
So i am assuming that there was an oxygen sensor located on that portion of exhaust that is now lost.
I thought no big deal I will just drive to a muffler shop and get it fixed, but the Ex would barely move. So i guess i will have to tow it unless someone knows how i can get the truck to run missing the pipe and sensor.
My questions are:
Is that an oxygen sensor that goes into the exhaust pipe?
If so, can i just buy the sensor and pigtail, wire it and then drive to get exhaust fixed?
Is there a way for me to drive it without wiring in a new sensor instead of paying for a tow?
2004 6.8L limited
Thanks for any help you can provide!
My questions are:
2004 6.8L limited
I didn't, it acts more like it is not getting fuel or is starved of air. I assumed that without the sensor and the bare wires maybe the computer was overcompensating or maybe something shorted out.
There isn't a whole lot of transmission/transfer wiring on that side, but there is some. Check it for damage. I guess it is possible that the O2 wires shorted against each other or shorted to ground during the destruction, thus screwing up the PCM.
I would do a through examination of the underside.
Wrapping exhaust around driveshaft? Really?
How did you get it off the driveshaft?
I would look at the fuel line, as exhaust pipe wrapping would have hit both sides and roof/floor. Possible crushed fuel line.
Inspect brake lines too and wiring that goes to rear of Ex.
Guess I should add that when I was halfway through my header install I had to drive it to my buddies shop that works at the local DOT and the headers were leaking and I was running the headers and Y-pipe only and drove about 8 miles with no issues. I just did every little thing I could to keep it from shifting early
