Mystery coolant leak - Ford Truck Enthusiasts Forums
Old 01-26-2016, 04:51 AM
tigerlady1221
tigerlady1221 is offline
tigerlady1221 is starting off with a positive reputation.
Hi, I have a 2002 F150, 4.2L that is leaking coolant. I thought it was coming from the waterpump and had that replaced but it is still leaking. The mechanic insists he has pressure tested it and isn't finding anything yet I have a puddle of coolant under my truck every morning and my coolant level is down about a 1/4 " after each use. It looks like it is leaking from a couple bolts where the wate pump connects. But the mechanic claims he would see it leaking when he pressure tests it and he isn't seeing anything. Can anyone help me?
Old 02-02-2016, 08:53 PM
rustybuttrusty
rustybuttrusty is offline
rustybuttrusty is starting off with a positive reputation.
Having been in the automotive business, (specifically cooling system repair) I can tell you that I have seen leaks in systems without pressure in them, however pressurizing the system halts the leak. My advice would be to drain and flush the system thoroughly refill with clean PLAIN water then perform a pressure test. Also, after you've refilled the system allow it to come up to operating temperature and top the system off and pressure check it. Allow the truck to cool completely and re-pressurize it to check for leaks.
Old 02-02-2016, 09:49 PM
1saxman's Avatar
1saxman
1saxman is offline
1saxman has a good reputation on FTE.1saxman has a good reputation on FTE.1saxman has a good reputation on FTE.
Could be as simple as a bad hose but you'll have to do what Rusty said if you want to cut your losses and find the leak.
Old 02-03-2016, 10:26 AM
tigerlady1221
Thanks Rusty, I'll pass this info onto the guy helping me out since I dont trust the original guy that worked on it for reasons that don't need to be posted here.
Old 02-03-2016, 04:41 PM
rustybuttrusty
You're welcome, good luck.
markmcg
11-13-2018 06:15 AM
northernroots
12-28-2017 07:17 PM
Boomer89
09-01-2017 04:59 PM
Mr Boogie
6.4L Power Stroke Diesel
31
02-17-2017 07:39 AM
c mobley
64
08-17-2016 07:21 PM
Quick Reply: Mystery coolant leak
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
