Runnin board bent
I was using a 40 foot aluminum ladder to caulk some windows one time. Went to move it and it got away from me. When it crashed to the ground it bent it about 2 inches. Me and the guy I was working with put it crown up on the curb. I held it and he jumped on it a few times. Good {almost} as new. Maybe the running board needs a massage in a similar manner, no jumping though.
I would be tempted to flip it over and put a small block of wood under each end and pull it with big C-clamps or stand on it. The gouge in the outside rounded area might be able to be dinged out using a piece of pipe or something round that matches the radius and beat it out. Keep in mind that I am not a paint and body man.
This is only an amateur opinion from an amateur mind, but maybe a jack under the bowed point in the RB using the trucks weight and possibly some heat ( with RB still attached to truck). Or taking it off and applying weight on the bow while it sits on a flat hard surface utilizing some wood to help as stated in p #4. As far as the outside curve I used a galvanized fence pole clamps and Hammer and dolly, with some success. Like its been said its some tuff stuff. Good luck Schoo
The metal on the rail was stretched (3 deep dents)so now I have pucker to fix this week end but all straight but a 1/4" and it lays flat on the brackets
bigwin56f100
03-19-2015 07:03 PM
davewave649
06-21-2011 12:15 AM
Drewski 2
40
02-02-2011 05:54 AM
