Boost tester is in the glove box. It was tested and that did not show as a leak. I will know soon as I have put the stock turbo to plenum piece in. If it builds boost then I will remove the grill and test the rest of the system.
The truck now makes 22psi and 1200* is harder to get to. I feel like a fool. Last time I had the spider out I spent a lot of time making sure the oring was in there.
Ugg that's some nastiness sir. You need one of deeze rust free ones!!
I am looking for one
It seems to come in waves here. I was under the hood looking for a fuel leak as it smells like fuel. Valley was dry all looked good. Then I noticed the heater hoses.
