Automated Safety Hitch System
Greetings! New to Fifth wheelers in general ...
I'm trying to decide F350 vs F250 which seems to be essentially pin weight ... Does anybody have any opinions about the "Automated Safety Hitch System" (ref The Automated Safety Hitch | Trailer Hitch | Gooseneck Horse Trailers | 5th Wheel RVs | Flatbed Goosenecks | Fifth Wheel ) seems like an interesting way to solve pin weight limitations on the 250, plus the added advantage of extra brakes! Of course everything looks good on a companies website. I'm looking for anyone with actual experience/opinions on these things.
Thanks in advance!
Thanks in advance!
I saw a link to this before. Looks like a whole new world of potential problems, overall length is increased, on tight turns it would be a nightmare, potential for jack knifing under heavy braking, additional combined weight. I can see that it is a way around having a truck that can't take the pin weight of your trailer but surely the safest solution is to get the right truck. JMHO
At over $12K, it would add probably 10 feet to the already 58 foot overall length of my truck and 5er combo. Then there is the fact that it's a ridgid attachment to the vehicle's frame, adding a lever waaaay back there to add to the potential of steering miscalculations. I also wonder what how that frame extension handles sudden terrain rises as often seen in CGs. Since I can't open the sites posted Recall Notice, makes me wonder what that problem is. I'll stay 'close coupled' with the trailer hooked up to the bed mounted conventional B&W hitch. And for sure, any conventional hitch is a LOT easier to hook up
While valid points are made I have yet to find anyone with actual first hand experience with the ASH. I want to hear the downsides personally experienced rather than theory, especially since their videos and their website is very convincing.
We looked into the system and found out it was going to be about $12,000 just to buy it. Having to have more tires to worry about monitoring, more things going bad, more length and the added cost was enough for me to have second thoughts.
Our thoughts were that the initial cost is too high. That extra money can be better spent on a better 5er and the price increase from a F250 to a F350/F450. At least if you invest in a bigger truck you'll get the money back out of it when you sell/trade it. Good luck selling the ASH after you've gotten your use out of it.
Thanks in advance!
Thanks in advance!
Judging by your post it appears that you may be a distributor of this product...but I'm assuming not.
Fwiw the difference in srw 250 and 350 is nothing more than the badge for the most part with very few exceptions. Some choose to pay for the sticker and higher registrations, some dont.
From an engineers perspective (mine) the amount of lateral forces applied to the truck frame would be far in excess of what the frame could safely handle.
Also, what happens when traversing down a steep gravel grade with this system? I sure hope that the trailer doesn't push that cart out of its way (it will!). At least with the truck under pin you can turn into the skid and save it.
Let's not even about icy roads and such.
This is the same as the two wheeled tire gizmo that inserts in to your hitch receiver to increase payload and looks like a small set of training wheels. I.E. Not necessary and dangerous to say the least.
Recall of 86 Automated Safety Hitch Systems due to incorrect lug bolts/wheel studs installed by axle manufacturer.
The axle manufacturer installed the wrong lug bolts/wheel studs on the axles of the following Automated Safety Hitch Systems.
Dash five bolts were installed where the stronger shear strength of dash eight bolts were specified by the axle manufacturer.
With the axle manufacturer taking too long to initiate a recall, Automated Safety Hitch Incorporated is initiating this recall ourself.
Any manufacturer of any product for that matter.
