The age old P0401
The age old P0401
97 4.6
So it would appear that I have the wild goose chase of codes. The major symptoms are rough idle and very poor performance.
I started off by cleaning the egr valve and ports. Then I checked the egr valve itself and watched the valve open and close under a vacuum. I was suspecting the DPFE sensor but I wanted to trying something else first. I was under the Impression that if at idle you apply a vacuum to the egr valve it would cause the engine to "stumble and stall". I did this and there was no change in the way the engine was running. So now I'm lost as to where to go from here.
vze2sgxa
1997-2006 Expedition & Navigator
12-04-2018 07:38 PM
WINGNUT-
08-11-2010 08:20 PM
vze2sgxa
1997 - 2003 F150
12-30-2008 09:57 AM
