!!HELP!! 2007 Super Duty need the best Ford minds for door lock/ keyless entry problem
It does sound like it didn't come with RKE, and yes, the power door locks should work, assuming they have the solenoids and are plugged in.
At this point you are going to need to pull the door panels to physically check wiring in the doors to see if the power locks are present and connected. The doors could have conceivably been replaced or the locks removed. If the locks are present and connected, start at the switch to look for power and follow the wires back until you find where the power is being lost.
As for RKE, you'd probably be money and pain ahead to purchase and install an aftermarket unit. You could buy an RKE with remote start for less than the cost of OEM. If you do go with OEM you are going to have to have the PCM flashed by the dealer.
So assuming I don't have a RKE does that mean there is no module that controls the door locks that I need to worry about? I read somewhere that some people are having luck disconnecting the battery for a few.
These days, everything goes through some sort of control module. The question is whether or not it is one that requires being flashed or not.
dscabra and I agree that you need to physically inspect the system before you can get much further.
AllaboutMPG
Electrical Systems/Wiring
07-21-2014 07:43 PM
viperbluelx
1999 to 2016 Super Duty
05-31-2007 09:06 AM
