1993 460 running rough and fumey
Old 01-19-2016, 11:40 AM
wahlturfcare
wahlturfcare is offline
wahlturfcare is starting off with a positive reputation.
lately my '93 truck started running rough and has been getting pretty fummy from the exhaust where it is strong enough to get on your clothes. It is the worst when the truck idles.
I did pull codes dtc311 and 332 during the KOER test.
I also noticed the front if the intake is wet around the gasket area. Would a leaky intake be causing this?
Old 01-19-2016, 11:50 AM
rla2005's Avatar
rla2005
rla2005 is online now
rla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud of
IMHO it's almost pointless to run the KOER tests. Start with Key On Engine Off (KOEO) and stored code (aka Continuous Memory) display.
Others may disagree.
FWIW:
Code 311 (KOER): Thermactor air system inoperative (right side)
Code 332 (KOER): EGR valve opening not detected.
Old 01-19-2016, 12:17 PM
wahlturfcare
I tried and I couldn't get it to bring up any stored code's.
Old 01-19-2016, 03:56 PM
Lead Head
Lead Head is offline
Lead Head is a name known to allLead Head is a name known to allLead Head is a name known to allLead Head is a name known to allLead Head is a name known to allLead Head is a name known to all
If there's no check engine light, there may be no stored codes. The thermactor code may be the cause of your fumes though - that's the air injection system and I believe it's necessary for catalyst light off.
Old 01-19-2016, 04:22 PM
rla2005's Avatar
rla2005
If the truck will run the KOER tests it will do the same for the KOEO. As well. The CM (stored) codes are displayed after the any KOEO codes are displayed.
Keep in mind if all the KOEO tests pass you will get the System Pass code of 111. There will be a separator pulse that some code readers interpret as Code 10, this is false. Once the separator pulse is triggered any stored codes will be displayed. If there are no stored codes you will once again get the System Pass code 111.
dragford
15
01-10-2017 07:32 PM
GRanger86
General Automotive Discussion
08-18-2016 07:45 AM
Skydivelout
04-01-2016 05:16 PM
chas111
1999 to 2016 Super Duty
02-13-2016 03:57 AM
Fluke01
2004 - 2008 F150
01-11-2016 05:25 AM
Quick Reply: 1993 460 running rough and fumey
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
