92 Ford F-250 5.8l W (IDLES HIGH)
Old 01-19-2016, 11:30 AM
Gooz's Avatar
Gooz
Gooz is offline
Okay I need help trying to find the reason why my engine is idling high. I probably made a mistake by washing the engine. Because since then it idles high. Can someone tell me why.
All I did was change oil, flushed out cooling system and replaced thermometer and the housing, and washed the engine. After washing it I turned it on and it was idling high I took it around the block and it was still doing it. I turned off and then wouldn't turn back on do to water in the distributor, so I dried it and now it starts but still idles high.
Old 01-19-2016, 11:55 AM
Lead Head's Avatar
Lead Head
Lead Head is offline
You may have gotten water in your idle air valve. It's the large metal canister bolted near on the throttle body with a wire coming out of it.
Take it off, and see if the plunger inside still moves freely.
Old 01-19-2016, 12:16 PM
Gooz's Avatar
Gooz
Gooz is offline
Okay i have it off what do I use to see if it moves without damaging it?
Old 01-19-2016, 12:33 PM
RIKIL's Avatar
RIKIL
RIKIL is offline
look for broken vacuum lines. If you have the original lines, they can be brittle and break when old. That will cause a high idle.
Old 01-19-2016, 12:55 PM
subford's Avatar
subford
subford is offline
Sometimes when you wash the engine bay you will then let the smoke out of the PCM.
That will cause the high idle too.
Lead Head's Avatar
Lead Head
Inside there is a shaft that moves back and forth with a plunger in the middle. Just stick a flat head screw driver in there and start wiggling an see i it moves.
Old 01-19-2016, 04:58 PM
rla2005's Avatar
rla2005
rla2005 is online now
Received 1,153 Likes on 911 Posts
A diagram of the IAC shamelessly stolen from the Old Fuel Injection Technical Library:
Dale Snyder
1978 - 1996 Big Bronco
08-07-2015 08:15 PM
zeke52
01-09-2013 06:22 PM
oldfordisbetter
01-01-2011 09:23 AM
JBronco
07-02-2009 11:40 PM
Quick Reply: 92 Ford F-250 5.8l W (IDLES HIGH)
