89 F250 w/460
Old 01-18-2016, 01:34 PM
hawk48rq
hawk48rq is offline
hawk48rq is starting off with a positive reputation.
89 F250 w/460
Fairly new here but have a question for you guys.
I recently bought an 89 F250 that is supposed to have a newer 460 in it but I don't know where to look on the motor for any numbers. The manual says that they are on the valve cover but I cannot see any numbers.
Any suggestions of where else to look.
Thanks
Old 01-18-2016, 01:45 PM
Bruzz's Avatar
Bruzz
Bruzz is offline
Bruzz is starting off with a positive reputation.
I know on older blocks, I was able to find the #s on the bottom of the block. Hope this helps.
Old 01-18-2016, 01:54 PM
hawk48rq
hawk48rq is offline
Thanks Bruzz, do you know where on the bottom of the block. I know where to look on a GM block but not a ford.
Old 01-18-2016, 03:07 PM
Bruzz's Avatar
Bruzz
Bruzz is offline
I believe its back near the starter and freeze plugs.
Old 01-18-2016, 04:40 PM
hawk48rq
hawk48rq is offline
Bruzz
Thanks much, I will take a look.
Old 01-18-2016, 11:34 PM
bbf385's Avatar
bbf385
bbf385 is offline
bbf385 has a good reputation on FTE.bbf385 has a good reputation on FTE.bbf385 has a good reputation on FTE.
The block won't tell you anything. They are all the same casting after 1979.
Look on the heads right above the two center exhaust ports (2&3 or 6&7) If it says F3TE then it is the last heads made, if it says E7TE then they are original or at least the same heads that came with the truck new.
Old 01-20-2016, 07:59 AM
Bruzz's Avatar
Bruzz
Bruzz is offline
Thanks bbf385.... I learn something new every day!
wtrfwl havoc
04-10-2017 09:13 AM
Rockjeep
03-05-2017 04:35 PM
F250 89
11-02-2016 05:42 AM
Acab1
41
07-20-2016 06:10 PM
Kyle Campbell
04-13-2016 08:56 PM
Quick Reply: 89 F250 w/460
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
