no compression
Old Jan 21, 2016 | 04:58 PM
  #31
bobv60's Avatar
bobv60
I won't waste my time with you but I KNOW for a fact that my torque pro and live wire TS read actual pressure.
Old Jan 21, 2016 | 07:00 PM
  #32
texastech_diesel's Avatar
texastech_diesel
Token Redneck
Torque Pro has a PID that comes as "HPOP", IIRC it's coded as ICPV mapped against a conversion table to PSI. That doesn't change the fact that the PCM will not report an actual ICP reading in psi. Not sure if it's one that comes with the Pro version 6.0 extended PIDs or if it has to be coded, I never paid for the real version of Torque.
Scangauge, DashBoss, and Edge will not show actual ICP in PSI.
Old Jan 21, 2016 | 07:35 PM
  #33
bobv60's Avatar
bobv60
Exactly. It's not hard to convert ICPV to psi. A lot of scanners do it. But I do have to admit that the first "mechanic" that looked at it really didn't know what he was doing so it is possible that he looked at the wrong PID.
Old Jan 21, 2016 | 10:17 PM
  #34
run6.0run's Avatar
run6.0run
I've seen engines that sit for a while have low compression. If the oil is basically bled off the lifters the valves might not be opening fully. That would give a funky crank. How much did you crank it?
Old Jan 22, 2016 | 05:04 PM
  #35
Rusty Axlerod's Avatar
Rusty Axlerod
ScanGauge, DashBoss, and Edge will not show actual ICP in PSI.
Help me understand this part in red?
Old Jan 22, 2016 | 06:05 PM
  #36
texastech_diesel
Token Redneck
They show ICP_DES, not ICPV converted to PSI.
Old Feb 1, 2016 | 04:22 PM
  #37
fatherof7's Avatar
fatherof7
no compression
sorry for the delay out of town, just got the compression passenger side front to back 160 100 80 41, drivers side 120 0 20 10. obviously very low my question is would sitting for 1 year cause enough gunk on the heads to block the valves,would bad head gaskets cause this or any other ideas?
Old Feb 1, 2016 | 07:46 PM
  #38
bobv60's Avatar
bobv60
How much time between the passing er sidding and the drivers side? Those numbers could indicate a plugged exhaust if all the glow plugs where not removed before starting yhe test.Did you have a battery charger on it during the test? A week battery causing slower cranking will also show a steady decrees in compression.
Old Feb 2, 2016 | 01:12 AM
  #39
run6.0run's Avatar
run6.0run
I've yet to see an engine that I couldn't start,, unless it has a hole in the block or the crank is locked up. It might cost a starter,, but I would make sure it's full of oil and crank the heck outta it. 0 compression is crazy tho. This one was zero
I started this truck and pulled it in the bay btw
Old Feb 2, 2016 | 02:02 PM
  #40
fatherof7's Avatar
fatherof7
the glow plugs were all removed and the batteries were new. we did crank on it for a long time and tried starter fluid and didnt hit a lick. havent taken the heads off yet but unless ya'll have something different in mind i think thats next
Old Feb 2, 2016 | 03:37 PM
  #41
bobv60's Avatar
bobv60
I would do a leak down test. Put compressed air into the cyl and see where the air is going. Make sure the intake and exhaust valves are closed on the cyl you are testing. You don't really need a tester. Just regulate air pressure to about 50 psi and listen to where the air is going.
Tyrone_White
1997 - 2003 F150
Jan 1, 2018 07:30 AM
SKaero
Aerostar
Aug 16, 2016 11:59 AM
Brewmaster
General Diesel Discussion
Apr 18, 2014 11:08 PM
truck crazy man
17
Feb 6, 2014 07:50 PM
ghak
19
Apr 6, 2003 12:46 AM
