2000 excursion with 2015 f350 chrome front and rear bumper
#47
Bolt on question
Hello gentleman. After coming across this thread and seeing how nice and clean this bumper mod looked on the X, I started searching for a new take off for mine. Thanks a lot!
I found new front and rear take offs a few hours from me that are complete with all the plastics and lights etc. My question before I invest 6 hours of driving is are there brackets that I would need off of the truck that the bumpers came off of? I don't want to get into a situation where I invest time and money to have to go searching for other parts to make it work. Speaking of spending more money, has anybody had any experience with the above mentioned Warn winch gap fillers from the hidden hitch kit? Part # 85420
Thanks in advance for any advice or help.
Sorry for the long first post!
Shawn
Shawn
Last edited by eXdiesel; 06-21-2016 at 11:26 PM. Reason: Details were already mentioned
#48
Shawn
Shawn
#49
If I pick these up I do plan on ordering the Warn fillers for the ends and it also comes with a top piece that I dont think I will need.
I should have mentioned that I have a new full size 2007 grill still in the box that I never got around to cutting down to fit my 2002. Does the cut to fit version fit better than the uncut?
By the way, your X look great with the bumper and lights. Are those the stock bulbs in your fogs? They look super bright.
#50
When you say not a perfect fit, are you referring to the ends not being long enough or will I have to make modifications to install it?
#51
#52
I do not believe you can use the side mounting brackets because they're too short, but get them anyways. You will only be able to use the center mounting brackets that your old bumper used.
#53
#54
There we go..you will only use the front mounts off the bumper and I feel the bumper would work if I was involved in a accident. The sides of the bumper will not seem like they're loose as you will not be able to use the side mounts, but please get they as maybe you could fab something up. I did not . Take your grille off and get an idea where it will come to and mount your 06 grille to see where you look at and vice versa with the grille.
#56
#59
Your Excursion looks fantastic! I just bought our second one, a 2000, 7.3 4x4, and I am really drawing inspiration from the posts here. This is exactly what I want to do to ours. A couple of questions, if you (or anyone else might wish to chime in) don't mind:
1) What size spacers (I am assuming wheel spacers) did you have to go with on the Platinum 20's? This is new to me, and forgive my ignorance.
2) With regard to the 2007 upper lights, grille, emblem, etc. Did you purchase aftermarket parts, and if so, are there any caveats to watch out for, e.g., quality, etc.
3) Did you swap the header of yours with the 2007 header?
4) On the 2015 Bumper, I read the posts, and am curious if I understood that the new bumper will basically bolt right back on to the 2000 factory brackets? Or do you utilize the 2015 brackets?
5) Where's the best place to order the mirror upgrade you used?
Thanks for taking time to read and or answer. I appreciate it, and am excited to be working on this new project. Fun stuff.
D
D
#60
D
D
Welcome aboard to the best EX forum on the web!
I'll help out with the easy ones.
1) For the '05+ Super Duty 17", 18", or 20" rims you will want to use 2" thick "hubcentric" wheel spacers. The OEM setup uses the hubcentric rim mounting system where the rim centers on the hub's little lip vs how typical rims are centered by the tapered seat of the lug nuts. These hub center rims use flat washer faced lug nuts for the clamping force.
5) A1auto.com is a site sponsor and has a huge selection of top quality aftermarket mirrors with a wide variety of options. I've had their '08+ mirrors with power adjust, heat, smoked signals and chrome caps for 3+ years now and perfectly happy with them.
