1996 7.3 diesel losing power
I have a 1996 f250 powerstroke 5 speed 4x4. It starts right up everytime and runs fine at low rpm's but if I hold the throttle at 2200 for around 30 seconds the rpm start dropping and the foot pedal has no response for about 30 seconds and then goes back to running fine at the lower rpms. I have dual tanks and this occurs regardless of which tank I'm running on. Brand new turbo at the end of summer. Lift pump and cps didn't fix my problem. No oil in icp. No fuel leak that I can find. Unplugging the map sensor didn't change anything. I'm new to working on a diesel truck so anything helps. Thank you guys.
Phil P SR
07-19-2017 05:55 PM
Firedevil
01-31-2010 07:54 PM
David Melnychuk
11-15-2004 04:57 PM
