A Little Help with Glow Plug Troubleshooting
My 1999 7.3 PSD (165,000 miles) died on the highway the other morning when it was -20 F. Fuel gelling was the likely cause. Dummy forgot to add anti-gel before fueling the week before. I got the truck to restart and ran it missing and sluggish to get off the pavement. Now it will note restart.
Here is the situation currently:
Plugged in block heater.
Added 911 Red to the tank.
Added 911 Red and diesel to the fuel filter bowl.
Filter bowl drains and refills. No gum, crystals of junk in filter.
Replaced Glow Plug Relay.
Cranks but will not start.
SO, I want to check if the GP Relay is getting orders from the PCM. Here is the question about trouble shooting this.
I remove the two small wires from the GP Relay,
With jumper wires, apply voltage from the battery across the two small terminals. If the voltmeter reads voltage on the big output terminal the GPR is OK and the problem is in the PCM circuit that tells the GPR to activate. Right?
I do not understand what "apply voltage from the battery across the two small terminals" means exactly. What do I actually do here? Does this mean run a wire from the battery to one of the small terminal and then connect to the two small terminals with a jumper? I do not want to screw this up and damage the relay.
If the GPR is activating then the next step it to test the GPs at the connector.
If anyone can make this a little clearer I would appreciate it. Thank you for any advice.
The two small lugs on the relay are the power to the coil. One is positive and one negative. The positive wire from the truck should be hot whenever the ignition is on. The other wire should carry ground while the PCM is commanding the glow plugs on. If you want to power the relay independent of the PCM, remove both wires from the small lugs and connect one to +12vdc and the other to -12vdc. The lugs are isolated from the case and each other, so as long as both of the truck wiring harness wires are disconnected it doesn't matter which lug gets positive and which gets negative. Do not connect the small lugs to each other.
Thanks.
I wanted to be clear on this and did not know what the small terminals were exactly.
The GPR tests hot with the ignition switch on so the starting problem may be the glow plugs themselves. They were replaced 87,500 miles ago and may have failed with my repeated attempts to start while stalled on the road side.
I wish the GP pin connector was more accessible for testing!
Thanks again!
Thanks again!
hunterguy86
15
01-20-2010 05:30 PM
quiethorse
12-07-2004 11:00 PM
