Adapt jaguar brake lines
standard double flare with M10 x1 brake line female nuts to attach a 3 1/6" brake line to the jag XJ6 hose. I get the nuts from the jag donor, but I did find one place selling them online.
M10x1 brake nut, female - Brake Pipes (Copper) & Fittings - Brakes - Parts by Category
In this picture you can see the male end of the jag hose where the line will hook up, I did the same on my F1s.
Dave would these be the same? M10-1 to 3/8"
The weatherhead 7934A is steel
NAPA AUTO PARTS
The Gates G49400-1010 is Brass and may be discontinued
Gates Mega Crimp G49400-1010 - Hydraulic Brake Union | O'Reilly Auto Parts
NAPA AUTO PARTS
Joe,
The parts you listed look to be unions, so they should be threaded on both ends with the M10x1 thread, correct? The part I listed is the actual female nut needed to attach a brake line directly to the jag hose which is threaded on one side only (bad picture of the part ) Or if you could find a union with M10x1 on one side and a thread to accept a 3/16" brake line nut you could use that, but I don't like using adapters unless there is no other way.
EDIT found a dorman adapter, M10 x 1 to 3/16 PN 43512
http://www.dormanproducts.com/p-1568...origin=keyword
Joe,
Dorman Products - 43512
Dancingchicken
07-03-2009 11:07 PM
64F260
13
03-05-2007 10:24 AM
bigbronco88
09-10-2004 08:19 PM
