Cranks won't start...Need a Checklist
#166
The chart in this link, https://web.archive.org/web/20071015...tion.com/?p=28 , that Subford provided does go below the 50*F. That's where I got the -40*, roughly, reference for the 111K resistance I'm getting.
I am getting 4.6 Volts at both connectors with them unplugged.
#167
Myself at this point I'd just replace those two sensors, again it falls to they are cheap easy to change and more to the point they are likely original to the truck.
You either have a fairly large margin of error in your meter down that low or you have a reference voltage problem. I lean toward the meter but only way to know would be to try another meter or test yours with a known value.
Your resistance value yea puts it near -40 but your reference voltage wouldn't allow it to reach that might not even break 0deg, that is provided for example that your reading of 4.6v is accurate.
A meter checking for 5v actual should only be a small amount off if any, 4.9v or 5.1V for example.
Point is your tests really don't tell you much, wish it was more concrete for ya. Myself I'd replace the sensor with a fresh one and see how it starts/runs with no other change made then go from there.
#168
When I had checked, at the ECT anyways, yesterday the voltage was dead on at 5 Volts. I think at this point my battery may not be 100% which could possibly cause the slightly lower voltage right?
#169
I believe its just your meter.
I would replace the sensor with a fresh one if for no other reason to rule it out and to provide the computer with the most accurate information it can get. We are talking about a sensor that is very likely to be 22+ years old and based on your tests questionable at best.
#170
#171
So to revive the thread momentarily for those that helped out. It ended up being the IAT sensor. Pulled it and it looked quite the worse for wear, I've attached a link to a pic of it. She starts right up and runs great with the new one. So thanks again to everyone that helped along the way.
http://rs867.pbsrc.com/albums/ab240/bensweeney/Mobile%20Uploads/IMG_20160220_112504399_HDR_zpsqazzpgzk.jpg?w=480&h =480&fit=clip
tubby12729
09-04-2012 09:41 PM
Grey86r
12-01-2011 08:43 AM
polarisman729
02-24-2008 03:53 PM
