Have to rev engine to put in reverse when its cold outside
Hi... new here,
I have been searching the forums for an answer to this problem I am having with my 2000 4.6L truck. I haven't had any luck, so I am hoping someone here might be able to point me in the right direction.
When the outside temps fall below about 40deg F, I have to rev the engine a little (approx 2100 rpm) in order to get the transmission to shift from park into reverse. If I don't do this, it bogs the engine down and the motor dies.
Once I am in gear, everything works normally. I have no codes or lights. I have tried a new IAC valve, checked and replaced the trans fluid and filter. This is a very strange issue to be having. It SEEMS like it might have something to do with fluid flow? Like maybe the transmission cooler is plugged partially?
Any help would be greatly appreciated!!
Maybe I didn't do a good job describing it.
When the outside air temperature is below roughly 40deg F (and the engine is cold, hasn't been running in 24hrs), if I don't rev the engine the motor will bog down and die when I shift from park to reverse. And the colder the temperature, the worse the symptoms.
Once it is in gear (reverse in this case) everything works normally.
The fluid is new and at the proper level.
The IAC valve is new.
I am wondering if it might be the Torque Converter Clutch solenoid OR a restriction in the flow of ATF through the cooler.
Would a fluid restriction in the cooler CAUSE symptoms similar to this? I have found some sources that say it would. I am wondering if anyone here has had a similar issue and what the cause was.
msnrasool1
1997-2006 Expedition & Navigator
18
01-24-2018 08:32 PM
hgufrin
15
10-24-2017 02:39 PM
