1990 f150 5.8l e4od won't idle smooth
Old 01-22-2016, 07:10 AM
subford's Avatar
subford
subford is offline
subford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud of
Originally Posted by FordWithAproblem View Post
I'm having the same issue with my 4.9l il-6. Could it be the PCM also?
Your 1990 has it in the same place as above.
Old 01-22-2016, 09:17 AM
FordWithAproblem
FordWithAproblem is offline
FordWithAproblem is starting off with a positive reputation.
Ok, but I can hear my fuel pump click on and off like it normally should. If it's not the pcm what else could it be?
Old 01-22-2016, 09:36 AM
subford's Avatar
subford
subford is offline
That just tells us the clock is working in the PCM computer.
Do you have spark with the SPOUT removed and none with the SPOUT in place?
Old 01-22-2016, 09:56 AM
FordWithAproblem
My truck will run. but it runs funny, really shaky the idle bounces up and down. It's acting like it's a vacuum leak, but I cannot find one.
Old 01-22-2016, 10:22 AM
subford's Avatar
subford
subford is offline
Sounds like the EGR valve is stuck open.
You need to run the EEC self-tests.
Old 01-22-2016, 01:57 PM
FordWithAproblem
How would I go about running an eec test?
Old 01-22-2016, 02:26 PM
Benztechnc's Avatar
Benztechnc
Benztechnc is offline
Benztechnc has a great reputation on FTE.Benztechnc has a great reputation on FTE.Benztechnc has a great reputation on FTE.Benztechnc has a great reputation on FTE.
See here on how to run a self test:
EEC Self Test
Old 01-25-2016, 02:09 PM
pbrogan
pbrogan is offline
pbrogan is starting off with a positive reputation.
ok thanks a lot
Down South 1
2011 to 2019 Explorer
39
10-02-2017 08:51 PM
Strokerboy73
03-23-2016 04:04 PM
BrokeItAgain713
03-03-2016 07:41 AM
Realslowww
01-03-2016 05:04 PM
Buck Dharma Fan
12-22-2015 08:55 AM
Quick Reply: 1990 f150 5.8l e4od won't idle smooth
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
