Custom suspended suede headliner installed and the panel for behind the seat is done now for kick panels and some other trim work and the interior is done
Little more work decided to change the door panel a bit just added a filler
I used a vw Tuareg rearview mirror with accent lights and auto dim. I took it apart and cut out some inner structure and bonded in a trimmed down section of the oem mirror so I could mount in like factory
It wasn't too expensive but it wasn't cheap either I worked with the upholstery guy he taught me how to do the work so basically I did most of the grunt work while he did the sewing and final fitment
