460 swap
Old Jan 12, 2016 | 11:27 AM
Jeremyntn's Avatar
Jeremyntn
460 swap
Do I just bought 1970 460 that I plan to put in the 1968 F100. Just wanted to know your suggestions on what would be the best type of headers to install with it?
Additionally I want to replace the manual three speed with atleast a 4 speed manual and preferably a 5 speed. Any suggestions there?
Thanks
Old Jan 12, 2016 | 03:31 PM
kenny nunez's Avatar
kenny nunez
460 swap
If your truck has a 360-390 standard shift, the flywheel will work on the 460 if it is an early version. As far as a 4 speed I had a wide ratio top loader from small block Mustang and could not break it. They have a 2.78 first gear and a wide ratio is 2.32, not good with 3.25-3.50. The close ratio styles only work with 3.70 -4.11 rear gears. I had a built 460 that I put in my 68 back in 74. A 5 speed will be nice as long as is a model that can take the torque of the 460. Change to a cable style throttle from a 73 and up. I had to use a clutch disc that matched the small input shaft on the top loader with a pressure plate that matched the fly wheel. Since the disc/pressure were not a match I had to put a 5/16" flat washer under each pressure mount hole so that the clutch would release. Convert to a hydraulic throw out bearing so that the headers will fit. Sanderson makes engine mount kits. Headers from a 74 F150 with a 460 will fit. Depending on your current engine you may need new front springs. The 360-390 radiator will work and you may need a different drive shaft. Hurst Competition shifter is the best. Get with it.
Old Jan 13, 2016 | 06:04 PM
Jeremyntn's Avatar
Jeremyntn
The truck does have the original 3 speed and the original engine was a 360, but now has a 302. The rear gear is 3.25
Old Jan 13, 2016 | 07:50 PM
kenny nunez
All that is left to do is to start throwing money and tools at it. I have a bell housing and the correct dust shield that locates the starter as well as a fly wheel that I will sell if you need them. The bell housing is powder coated the correct Ford blue. PM me if interested
Old Jan 13, 2016 | 11:52 PM
HIO Silver's Avatar
HIO Silver
A Tremec TKO 5-speed will live behind a 460. Contact Bruce or Paul at Modern Driveline and have about $2800 at the ready.
norcal_truckhead
Oct 21, 2012 12:14 PM
56f600
18
Dec 1, 2004 06:37 AM
pauldavis
Engine Swaps
Nov 5, 2004 12:19 PM
tsheriff
Nov 14, 2003 06:40 PM
fuzz
20
Jul 11, 2001 07:23 PM
