2016 6.7l first oil change - what a breeze
Unless you've drained the Oil pan first or turn the oil filter enough turns to shut off the valve, You still get oil dripping down the side of the filter. It will drain way more oil than just what is in the filter. And that takes forever to come out a ice pick hole.
on
I put the Fumoto valve on my truck and yes, if the oil is cold it drains slowly, however, I can use a 5 qt drain pan and just drain off a pan at a time to go dump into my recycle jugs.. That way I am not juggling 13qts of oil in a huge heavy pan.
Filter changing is just a bit messier.. Crack the filter loose with it's own drain pan and wait for the drizzle to slow or stop..
If you can, it's a good idea to pre-fill the filter most of the way which will minimize the amount of time it takes to get oil pressure into the galleys to the bearings...
When I start mine after an oil chg, I shut it off the instant it starts -- 2-3 times. This helps fill the galleys and filter and causes no harm to the systems..
To the OP: We could have a picnic on your garage floor. Nice!
