I have a 94 powerstroke (found out that it isn't a 95 ) 280k miles on it ,don't think that is anything to do with it but I'm concerned about my truck smoking when it's cold or at a start up . The truck is strong and doesn't skip or anything but it smokes really bad till it warms up and there is no tuners or chips , it's just straight piped. Any suggestions would be greatly appreciated!
Check your glow plugs. One or 2 will cause more haze than normal under start ups. But a light haze when the engine is cold, is normal for these engines
The only thing that leaks is the radiator so I can't do a coolant leak test till I get it replaced, and why glow plugs cause smoking ?
Because when the cylinders are not up to operating temps the fuel in not completely burned, which will cause it to smoke. The GPs raise that temp until the engine is warmed up. The GPs do NOT just turn on when starting, they will stay on for a good 5 min after the truck is running
One thing to remember is when its cold out you're going to notice it more just like you see your breath when its cold. My 97 with 240K does the same thing but is fine when its warm so I dont worry about it.
Here on Cape Cod it's been mild but we have had some cold overnights. On the cold mornings my truck starts fine but on initial start up it smokes and then after a minute or less it clears up. Warmer out not so much. It's got 200K.
