Hub or Ball Joints
Hub or Ball Joints
I've had a rattling/clunking sound from my front left wheel recently so I jacked up that corner. As soon as the tire elevated off the ground the bottom fell inward. I could easily push the top of the tire inward and pull the bottom of the tire outward. Does this lead to a bad hub or bad ball joint(s)?
I changed the left side ball joints and installed a new hub assembly. I have a couple questions:
1) When braking, when i get to about 6-7mph I feel a vibration in the pedal, I hear a whine/groan, and the truck pulls to the right. I assume it's something with ABS. Should I replace the ABS wire?
2) I wasn't exactly sure how to seat the upper ball joint. I set it so that the bottom of the BJ is flush with the knuckle. I could've pressed it in about another 1/8". Should I leave it flush, or should I press it in as far as possible? Or does it matter?
If it's pulling to the right, it probably is the left side not doing it's job properly. Pull the wheel off, inspect the pads for even wear, check the slide pins and make sure they move freely. Grease them while you are there anti-seize or go to the parts store of your choice and get some of that cheap brake parts lube that comes in the one time use packet. Make sure the caliper piston moves and the rubber seal is intact, etc.
